Old 04-10-2008, 12:29 PM   #1 (permalink)
toofan's Avatar
Unhappy Problem with USB: This device can perform faster.
This USB device can perform faster if you connect it to a Hi speed USB 2.0 ports.
This is the message which I get when I connect any pen drive to the my office PC.
It has two front and 4 back USB ports.
Earlier this problem was with the front ports only but now , one back port has started showing same warning and rest three ports are not working at all.
What would have gone wrong. Please help because the slower port are taking full one hour to transfer 3.5gb file.
toofan is offline
Old 04-10-2008, 01:41 PM   #2 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Re: Problem with USB: This device can perform faster.
Your office PC’s ports are USB 1.1, the older version of USBs…
Sooraj_digit is offline
Old 04-10-2008, 03:44 PM   #3 (permalink)
toofan's Avatar
Its not the case. Earlier there was no problem regarding USB ports. It works at full speed.
toofan is offline
Old 04-10-2008, 03:49 PM   #4 (permalink)
RMN
then maybe someone changed the USB speed in the BIOS
RMN is offline
Old 04-10-2008, 06:08 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
I posted a solution to this LONG BACK with screenshots but I cannot find the post. Anyway, here goes. Go to Control Panel->System->Hardware->Device manager
See if there are any yellow question marks against USB hub. If yes then right click on that and select update driver->No don't connect to the internet this time (to search for driver)
Next
It will automatically load the USB 2.0 drivers if it is XP SP2 or SP3
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
USB device problem Angad singh Hardware Q&A 3 25-04-2008 11:39 AM
BSNL Dataone Connection Problem : Unable to perform TCP/IP arnold Broadband and DTH 12 23-03-2008 09:46 PM
This USB device can perform faster if it is connected to HI SPEED USB 2.0 port HELP Sarvothaman Hardware Q&A 14 05-07-2007 09:53 AM
Hi Speed USB device can Perform Better Prabhagaran Hardware Q&A 3 06-06-2007 09:36 PM
Problem with USB device. anilkumar_kumar Hardware Q&A 8 15-02-2006 12:25 PM
- by kool
