Old 04-10-2008, 10:04 AM   #1 (permalink)
Default Help needed!
Hi,
i just bought a HD4870 and a gigabyte 790gx motherboard.Which slot should i insert the graphics card in-the 8x or the 16x.Which is the 8x and 16x slot?
Thanks
mohan.rv is offline
Old 04-10-2008, 10:19 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Help needed!
Originally Posted by mohan.rv View Post
Hi,
Thanks
I think 16X bcause 4870 is a pci-e 2.0 x16 card....
Just refer 2 the mobo manual there u will get the diagram of the slot required
Zangetsu is offline
What is wrong with youtube? napster007 QnA (read only) 3 25-01-2008 04:48 PM
What's wrong with my IE7 ? Nariman Software Q&A 1 23-09-2007 05:56 PM
Something gone wrong with ''My Computer'' shyamno Software Q&A 2 24-01-2006 09:20 PM
What's wrong with CPU-Z ? mohit CPU / Motherboards 2 11-04-2005 11:44 AM
What's wrong with the cd? callsriram QnA (read only) 14 09-11-2004 07:00 PM
- by kool
