Re: Will the SMPS Corsair TX750 fit into the Cabinet CM Elite 330/331???
An old frontech trenz.
Few weeks ago I bought a new config with Corsair TX750. I didn't buy a new cabby and everything is fitted well.
One side's lid is always open, so heat isn't a issue.
Main thing is I've seen the pics in google and it is bigger than mine. Fitting won't be any problem.
rofl..... i guess i will have to fit more fans...coz there a lot of insects in the place where i intend to use the pc. so cant leave side panel open....otherwise insects will get fried in the 'tava'!!!
thanks man.
