I have a polk audio speaker that is approximately 8 years old. i upgraded my system and added a 945 motherboard, which comes with realtek hd audio driver. since then, sound is very low and i am barely able to hear. there is no defect with the speaker as connecting with an ipod, it works perfectly. what can be the problem?
pls help
thnx
pls help
thnx
have u turned on the voice cancellation or what???After all this did u checked out for the wires… if it is not crushed or whatever???
i guess compatibility shouldnt be making nuiances like this may be the alingment of the stereo pin of your speaker has different layout since it is a old one....
Hey check "Sound and Audio Devices" in contrl pnl.......is redirecting sound output to realtek or not.....
thn check weather ur media player is redirecting it through realtek or not......
or else borrow a speaker set frm sum1 check it on ur PC.........if it works f9.....thn thr is sumthng wrong iwid ur speakers or check the wires of ur speakers...........
