Old 03-10-2008, 12:31 AM   #1 (permalink)
Default 9600gt compatibility with d101ggc
i own a d101ggc motheboard with 2.66 P4 + 512 sd ram. i wanna buy 9600 gt nvidia card but ppl tell me that my pc configuration is slow and the card will not give its full performance on this pc. i wanna play Assasin's Creed and the upcoming TombRaider-Underworld.
Q1. is t true that the card will not give its full performance on this pc?
Q2. what is the bottle neck? p4, sd ram or d101?
Q3. what other vgacard options do i have?
oldicbian is offline
Old 03-10-2008, 12:53 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: 9600gt compatibility with d101ggc
I dunno if D101gc even supports PCIe Express 2.0 cards...so halt ur buying process a while.
And if it does, ur procc will be still okay, but u won't get the actual perforamance.
I suggest go for 9500GT PCIe card if ur mobo only supprts PCIe
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 03-10-2008, 03:02 PM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
I dunno if its compatible or not but it surely will be a bottleneck so dont buy it. Go for a full system upgrade.
Psychosocial is offline
Old 03-10-2008, 03:14 PM   #4 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Rather than buying a GFX card better upgrade your PC and play games on integrated graphics till you Purchase a GFX card
I spit Rainbows.
skippednote is offline
Old 03-10-2008, 09:01 PM   #5 (permalink)
ECE0105's Avatar
D101GGC was a basic Mobo from Intel... If you are tight on Budget, get yourself an 8600GT (256Mb DDR3). Otherwise, if you would probably upgrade the Mobo, Proccy etc. soon, then go for the 9600.... Cos the Motherboard and Processor would bottleneck the performance of the Card...
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Overclocking P4 on intel D101GGC ashiksn1 Overclocking 2 07-05-2008 11:20 AM
9600gt Plasma_Snake Gamerz 4 29-03-2008 09:05 PM
Dual Channel Memory on Intel D101GGC mobo ECE0105 Hardware Q&A 5 25-01-2007 08:02 PM
FC6 installation on D101GGC mother board roshan_aj Open Source 1 06-12-2006 05:50 PM
Intel® Desktop Board D101GGC FAQ zbuu Hardware Q&A 1 18-09-2006 01:54 PM
- by kool
