Hi everybody,
I have recently signed up for Broadband connection. It would take another month before I get the connection.
Ive subscribed for 500 c+ plan.
Im am wanting to buy a new router right away, as i will run out of cash by october
end.
Im looking for a very good and consistent performing wireless router, doesnt matter if its too technical.
My budget is 2000 Rs.
the ones in bsnl cost 1800 rupees and support wifi with one lan port. just get that u dont need a router . if ur planning to connect more than one pc, try linksys . they come in cheap and are good to
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
naah man, you can connect multiple computers using the BSNL router, and will be able to access internet from all.
It will create a local wireless LAN, except if you wanna utilise sharing things onto each system, you will find it slow.
Linksys or any stronger router which gives good speed for LAN would cost much more.
