01-10-2008, 03:31 AM
PC Not Booting... Please Help... Urgent...
Hi Everyone,
I have a PC with Intel E8400 processor, 4GB GSkill RAM, Corsair VX450W PSU, Asus P5Q Pro Motherboard, APC Back UPS-AVR500 UPS and a Palit ATI HD Radeon4850 graphics card.
I'm having a problem from last night. Before that my PC was running fine. When i start my pc, i get no display. The monitor LED just keeps on flashing on and off! Also when i press the power button, the processor and the graphics card starts, this i found out after looking at the fan speeds of both. But then it turns off for about 10 seconds and then starts again. But even then i get no display. Another thing is that, today i found out that the Asus P5Q Pro motherboard has no socket to plug in the monitor without the graphics card!!! Could you please tell me what could be the problem. I have a presentation to make and without my PC I'm helpless! Please help!
01-10-2008, 07:26 AM
The Black Waltz
Re: PC Not Booting... Please Help... Urgent...
That's one heck of rig. But will a 450W PSU be enough for such a monster? How long has it been since you assembled this rig?
#krow @ irc.freenode.net
01-10-2008, 07:38 AM
M3TAL H3AD M3
Did you check your ram and smps.
I spit Rainbows.
01-10-2008, 09:38 AM
dont forget to check the CMOS battery....it is the main culprit in such cases...especially with Asus MBs
01-10-2008, 11:32 AM
I am using the PC for a month now with no problems what-so-ever!!!
All of a sudden this problem showed up!!!
No I have no idea what the problem could be!!! I have shifted the RAM from one slot to another but it didn't help. PSU could be an issue although i don't have any idea about how to check that it is working or not!!!!I'll check the batteries as well and let you know!!!! Could it be the processor????
01-10-2008, 11:58 AM
www.system86.blogspot.com
I think the problem is with the graphics card.Just try cleaning it and put is back in the slot then try again.Make sure all the connections are ok.
01-10-2008, 02:25 PM
Ok... I will try out the solutions.... but may i have some more suggestions????!!!!
01-10-2008, 02:32 PM
EXIT: DATA Junkyard
That must be a HELL of a problem cause u made this thread at 3am in the mornin'.
Check if the plugs are correctly installed. I mean the 4850 to mobo, and monitor to 4850, and lastly check that your power connections internally are proper. Nxt up is to check if itz a dust problem, but itz not likely anywayz. Hmm, can u even enter boot? Oh th monitor doesn't start.gosh lemme thing
01-10-2008, 02:38 PM
Man the main problem is the I broke my PC Speaker while assembling the PC!!!
So i can even hear the beeps!!!
Beeps are a very good indication as to what's wrong!!! So i cant give you any clues about that as well!!!
The problem has really got me pissed off!!! I have my presentation due soon and the f*@$ing PC let me down at just the worst time possible!!!!
01-10-2008, 02:42 PM
EXIT: DATA Junkyard
Hmm, temporarily try to arrange for anything else. Letz see. Well, last time my PC did that, it started the nxt day to say that it was due to THERMAL OVERHEATING. But i dun think itz possible in a new PC.
01-10-2008, 03:10 PM
The Black Waltz
It could be due to the overheating. Install programs like Speedfan and use them to monitor the temperatures. If you notice anything too high, you know it's due to overheating. And, try all the suggestions mentioned above.
01-10-2008, 03:34 PM
EXIT: DATA Junkyard
The comp is not even starting^^^!!!!!!!!!!!!!!!
01-10-2008, 04:11 PM
The Black Waltz
Oopz.....
He has no choice but to open the cabinet, clean all the dust and check his PSU.
01-10-2008, 05:53 PM
filth is me
Did you mess with the BIOS recently? Clear CMOS battery if you haven't already. It would be very hard to say where the problem lies without hearing those beep patterns
02-10-2008, 01:27 AM
I recently had a similar problem.I have a MSI P35 neo combo motherboard.i upgraded the BIOS and after that i didnt get any display at all.I solved the issue by resetting the jumper and by just removing and putting back the battery.And it worked.Even my system starts and stops once or twice before it boots properly.
03-10-2008, 01:04 PM
03-10-2008, 01:08 PM
EXIT: DATA Junkyard
Yes do changit and tell us
..BTW how was ur presentation
03-10-2008, 02:29 PM
Originally Posted by hell_storm2006
I knew it man..its a typical ASUS problem..change the CMOS cell and if it happens again then you may need to reset the BIOS...keep your fingers crossed...  ..
BTW how old is your MB..
03-10-2008, 03:53 PM
#19 (permalink)
03-10-2008, 04:57 PM
#20 (permalink)
The Black Waltz
Changed the battery? Did it work fine?
06-10-2008, 10:05 AM
#21 (permalink)
Thats great. Then you can give a shot at this. Change the CMOS cell and if this thing happens again then reset the BIOS even then if problem is there then get it replaced from ASUS. If you need help them PM me and i'll give you the email ID of the top bosses of ASUS who will definitely help you...
I faced the same problem few months back and got a new board from ASUS (mine was 2.5 yrs old  )..
