Old 01-10-2008, 12:20 AM   #1 (permalink)
Default Help with Tv Tuner
Hi
i am planning to buy a TV Tuner. The problem i have is i have so slots left on my board
so it has to be either USB or some external card. I heard Pinallce, leadtech are good.
I need a good card so that i can also record with good quality. and i tried to google but not much help.
I can go upto 4-5k. Any suggestions
sudhir31 is offline
Old 01-10-2008, 12:39 AM   #2 (permalink)
aswin1's Avatar
Default Re: Help with Tv Tuner
Check this link.
http://theitwares.com/tvtuners/tvtuners.htm
aswin1 is offline
Old 01-10-2008, 11:59 AM   #3 (permalink)
coolsunny's Avatar
you can buy Gemini external USB TV tuner card..i m using it.Everything good so far.its 1600 in bangalore. might be less if u try in proper shop.
U can use it with laptop, for future.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 01-10-2008, 03:35 PM   #4 (permalink)
Point Blanc
get leadtech or Pinnacle if you really wann good recording.
Gemini or any local USB TV Tuner will run well but not that good for recording.
Besides this recording also depends on the input which mostly is low quality(in cables)
Pinnacle PCTV 50e or PCTV USB Stick
acewin is offline
Old 05-10-2008, 06:38 PM   #5 (permalink)
thanks for the info
i am from hyd so i will see wht i can find here
sudhir31 is offline
Old 06-10-2008, 12:42 AM   #6 (permalink)
Point Blanc
I had used a UMax USB TV Tuner card, worked fine for me the resolution it gave I think was 800x640 or something I suppose, picture quality was good, recording was alright, had tried a techcom earlier it sucked big time.
This UMAX one costed me 100 bucks more than techcom aroun 1800 that was last year. And when I knew little about TV Tuner cards and suppliers. But still can say the output was decent. would have been better with the digital input likes from TATA Sky and all.
acewin is offline
Old 07-10-2008, 06:44 AM   #7 (permalink)
I had used pinnacle for two years and i think it's best available in market and LCD range with this company is having very low time delay
_________________________________________________
Houston Gift Shop loans with no credit check pisos vilafranca download iPhone ringtones
sau07rabh is offline
Help with TV Tuner dimitrz Hardware Q&A 1 15-07-2008 05:22 PM
Need to go for a TV tuner Ace Ventura QnA (read only) 6 07-04-2007 12:44 PM
tv tuner with lcd..??? deepinder_mann1988 TVs / Monitors 1 27-03-2007 11:27 PM
TV Tuner maharajadhiraj QnA (read only) 1 23-01-2006 10:35 PM
tv tuner shaunak QnA (read only) 10 26-05-2005 01:42 PM
- by kool
