Old 30-09-2008, 10:35 AM   #1 (permalink)
channabasanna's Avatar
Default UPS is not a UPS
Hi All,
I have a Wipro UPS 600VA (donno exactly it is 600VA or 500VA), brought in December 2002. Last Year i had changed its Battery (EXIDE Battery) as i was not getting any backup.
Now whenever power goes off, the UPS switches off immediately . Is it a problem with the Battery, or any other Issue. No back up i am getting.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 30-09-2008, 04:04 PM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: UPS is not a UPS
Originally Posted by channabasanna View Post
Hi All,
Go to the Service Centre or dealer, anyway are you sure that the purchased battery is for UPS? Exide as far as I know is better known for INVERTER batteries, may be your's is one such.
UPS AND INVERTER BATTERIES ARE COMPLETELY DIFFERENT.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Old 30-09-2008, 04:33 PM   #3 (permalink)
Yeah the Battery worked for almost a year. And i am using a UPS only for PC, not any Inverters. The battery i got is may be of different brand i suppose, my brother had took the UPS to near by Exide centre and got its battery replaced. I think i should do the same now.
- by kool
