Old 29-09-2008, 09:17 PM   #1 (permalink)
Question Same old problem of processors and mo'boards
Hey guys, I am in a dillema.
I have a compaq presario desktop
(bought in march 2003) with AMD Athlon XP 2000+ andsome old motherboard(cant remember) and a 40GB 5400 rpm HDD with 16mb onboard graphics and 384mb ddr266 ram.
Let me divide the problem in 2 parts.
1. I want to change my computer. But should I go for an upgrade (processor+MB+HDD+Graphics Card+RAM) or should I rather buy a new branded PC? Which is better in terms of price effectiveness and in terms of reliability? (if branded, do give some suggestions with the specifications.)
My upgrade budget is Rs. 15000-20000, Branded budget is Rs. 45000-47000
I want the PC to be future proof(future as in 2yrs approx), ie. easily upgradeable. Please do mention the motherboard campany and chipset.
2. Is it true that an upgrade is a risky option(the components may not be as reliable as in a branded pc)?
I would be most greatful to you guys if you help me on this problem. I'm waiting for your suggestions guys.
blazkowicz is offline
Old 29-09-2008, 09:58 PM   #2 (permalink)
Default Re: Same old problem of processors and mo'boards
Iol I am in a similar position as u are.
I would suggest u get rid of old rig completely and buy a new one but not branded.
For 40k,you would get awesome rig by assembling .
Motherboard: Abit IP35-E 5.4k
Processor: Intel Core 2 Duo E7200 5.2k
RAM: Transcend 2x1GB DDR2 800MHz 1.8k
GPU:
Xpert Vision HD 4850 512MB 9.6k
HDD: Seagate 7200.11 500GB ST3500320AS SATAII 2.9k
Cabinet: Cooler Master Elite 33X ATX 1.7k
SMPS: Corsair VX 450W 3.2k
Optical Drive: L.G. H62N 20x IDE / Samsung 203B/D 20x SATA 1.2k
Speakers: Altech Lansing VS4121 2.6k
Monitor: ViewSonic 19" VG1930WM / Dell SE198WFP / L.G. L194WT 8.5k
Keyboard: Logitech Multimedia .5k
Mouse: Logitech MX518 1.35k
~~44,000
wait for what other techies have to say..
But I am sure u will not get such a rig for branded one
sahilshah1987 is offline
Old 30-09-2008, 12:44 AM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
Keep the budget of a new assembled PC @40k please......so we can suggest you a good PC.
E8400
MSI P45 Neo-F
2x2GB DDR2 800MHz RAM
WD Caviar SE16 640GB 7200RPM HDD
Palit HD4850
Corsair VX450W PSU
LG H55n Drive
CM Elite 330 cabinet
Dell E198WFP 19" LCD
Logitech Gaming G1 Desktop kbd+mouse
Altec Lansing BXR1121 2.1 speakers
Psychosocial is offline
Old 30-09-2008, 01:17 AM   #4 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
^^ Nice Config. +1.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 30-09-2008, 08:18 AM   #5 (permalink)
Point Blanc
I hope you got monitor already so except for monitor you can buy new specs, or say just a CPU as suggested by others.
acewin is offline
Old 30-09-2008, 01:38 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Here's one:
E7200 @ 5.4k
MSI P43 NEO @ 4.9k
HD 4850 @ 9.5k
ViewSonic 1940VX @ 10.5k
2x1GB DDR2 1066MHz @ 4k
250GB Seagate 7200.10 @ 3.2k
Corsair VX 450 @ 3.7k
Zebronice Bijli @ 1.3k
Logitech Laser Mouse @ 0.7k
Keyboard(logitech or Razer Tarancula) @ 0.8k
Check more options with prices:::
Hardware price list/spec sheet
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 30-09-2008, 02:20 PM   #7 (permalink)
Excessive happiness
furious_gamer's Avatar
Originally Posted by comp@ddict View Post
Here's one:
E7200 @ 5.4k
MSI P43 NEO @ 4.9k
HD 4850 @ 9.5k
Hope he already have a monitor..
Go for KPowerMania's config...Best VFM...
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
Old 30-09-2008, 08:23 PM   #8 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
First, if you actually ask the question "is assembled better or branded", that means you know little or nothing about computer parts. If that is the case, you would find it difficult to troubleshoot the PC if something goes wrong. So I strongly suggest you get a branded PC unless you have a friend who has sufficient knowledge about PCs to help you out.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 30-09-2008, 09:12 PM   #9 (permalink)
Point Blanc
Metal anyhow, assembled is better than branded, if he gets any problem, he will take to the shopkeeper and get it checked there. Eventually all companies are supporting their products.
acewin is offline
Old 01-10-2008, 01:12 AM   #10 (permalink)
^^ Exactly. But Branded PCs have support for more than hardware problems.
AOC Fovi F22
Old 01-10-2008, 01:48 AM   #11 (permalink)
Violent serenity.
^^Ya and it comes with Windows pre-installed(atleast in the PCs which cost 30k+) and it is genuine too .
Old 01-10-2008, 01:53 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Well, widout monitor if u keep the budget at 45k Then have a look at this.
Q6600 G0 @ 9k
Biostar i45 @ 7k
HD 4870 @ 16.5k
CM 330
VX 450
Gaming Kbd/Mouse Logitech
BenQ 21.5" @ 13.5k
About me:
Old 02-10-2008, 05:06 PM   #13 (permalink)
Thumbs up Re: Same old problem of processors and mo'boards
Thanks a ton guys! Your help was much needed by me.
Actually, I used to be an avid techgeek about a year or so ago, but now the pressures of Indian school curriculum(10th and +2) have diverted me from all this. So I was not in touch with the current developements in technology. Hence the dilemma.
The thing is, my father was told by the shopkeeper at a computer store that assembled PCs were not much good in terms of reliability and servicing. So my father became anti to an assembled PC. I knew, with my prior knowledge(a lot courtesy DIGIT), that I could build my dream machine if I go for assembled. Your posts have changed papa's mind, and I am very happy now.
God bless you all!
Old 02-10-2008, 07:35 PM   #14 (permalink)
Violent serenity.
^^AWESOME!!!.......assembled ftw...
Old 02-10-2008, 07:53 PM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
God bless you all!
I know, and totally agree to your view...I'm a tenthie too
About me:
Old 02-10-2008, 08:33 PM   #16 (permalink)
Ab koi mere baap ko bhi samjhao ye sab! Woh to abhi bhi apne celeron 1Ghz 256 MB RAM laptop se khush hain.
AOC Fovi F22
Old 02-10-2008, 08:40 PM   #17 (permalink)
Originally Posted by IronManForever View Post
Ab koi mere baap ko bhi samjhao ye sab! Woh to abhi bhi apne celeron 1Ghz 256 MB RAM laptop se khjush hain.
well they don't need what u need so for their need its enough ....
chilling.....
imgame2 is offline
Old 02-10-2008, 09:42 PM   #18 (permalink)
Violent serenity.
Ya......they dont need to play Crysis with everything maxed out .
Old 02-10-2008, 09:52 PM   #19 (permalink)
COOKING WITH HUMAN HEADS
I GOT SOME RIG WHICH IS 35000 WITH OUT MONITOR ---- TENDS TO HDTV AND FOR ULTIMATE GAMING
E8500 C2DUO -----------9200
BIOSTAR i45 -----------7000
palit hd 4850 --------------9300
2 gigs of ram 800 ----------1900
wd 320bg hdd ---------------3000
dvd samsung/lg -------------1000
cooler master extreme power 600 watts ----3200
case (cabinet) any of ur design-------------1100
total 35000--------36000 /////////////////
demonkingfromhell is offline
Old 02-10-2008, 10:35 PM   #20 (permalink)
Violent serenity.
^^Change your keyboard.....it has some problem with the Caps Lock button.
Old 02-10-2008, 10:40 PM   #21 (permalink)
still find time for games
arijit_2404's Avatar
Hahaha... nice way to say 'fu*k off"
PhenomII X6 1055T | Gigabyte 890GX | 4GB GSkill Ripjaws DDR3 | XFX HD5770 | Samsung 943nwx | Coolermaster Hyper TX3 | Coolermaster Elite430 | Corsair HX750
arijit_2404 is offline
Old 02-10-2008, 10:49 PM   #22 (permalink)
too good man ...
i m really laughing out loud on this one ...thats witty
chilling.....
imgame2 is offline
Old 03-10-2008, 01:55 AM   #23 (permalink)
Talking Re: Same old problem of processors and mo'boards
HEY u guys.... by the way it kind'a sounds like weird , that u guys had a joint ventures with each others , i am not an arrogant to keep up my answers , see do u belive that each tests for the cpu and gpu in the websites are rite ---------- if u r thinking like that means its not my fault,, try to seek the according to the tests by your own ... cool " i am not here to irritate you guys" if its gona make u guys like that i am sorry ----- beause i am not an egostic person
Old 03-10-2008, 06:19 AM   #24 (permalink)
Violent serenity.
^^We dont hate you or ignore you but you need to improve upon your typing. Your posts dont make sense because of innapropriate spacing and spelling errors. Otherwise, nothing personal .
Old 03-10-2008, 12:01 PM   #25 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Dude, we come make friends(although not joint ventures)
U'll hav to be jus a li'l careful while typing(not a warning, as an advice frm a friend)
Well, I'll tell u how I improved my typing, TUXType2, and I'm not joking.
I use all 8 fingers(litle fingers r a bit weak still) and my typo speed went up from a petty 45wpm to 68wpm in a month
About me:
Old 03-10-2008, 02:07 PM   #26 (permalink)
thanks about telling about tuxtype ..i will try it out ..i hope ..it does any good to me ....thanks once again ..
chilling.....
imgame2 is offline
Old 03-10-2008, 02:47 PM   #27 (permalink)
Violent serenity.
I suck at typing .
Old 03-10-2008, 02:56 PM   #28 (permalink)
I suck at typing .
me too ..infact i m very bad ...
chilling.....
imgame2 is offline
Old 03-10-2008, 08:50 PM   #29 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
68 words per minute
About me:
Old 03-10-2008, 09:04 PM   #30 (permalink)
Violent serenity.
68 words per minute
Never measured!
New Amd Processors comp@ddict Technology News 32 22-10-2008 04:22 PM
Help on processors.... kau_therock Hardware Q&A 2 30-07-2007 05:13 PM
amd processors ashfame Hardware Q&A 17 26-06-2006 12:14 PM
Difference between HT processors and Dual Core processors nil_3 CPU / Motherboards 2 18-02-2006 10:30 PM
- by kool
