Old 29-09-2008, 05:59 PM   #1 (permalink)
Wise Old Mouse
mrintech's Avatar
Lightbulb 3 Best Utilities to Monitor Your Hard Disk Health at it’s Best
Hard Disk Drive is most essential component as Processor and Motherboard. Without Hard Disk Drive your computer will be totally dumb. It’s very essential to Monitor your Hard Drive Health to maximize it’s performance as well as to eliminate sudden PC Crashes.
Here I will tell you 3 Best Utilities to Maximize your Hard Disk Performance as well as to Monitor it’s Health State.
  1. PassMark DiskCheckup - PassMark DiskCheckup allows the user to monitor the SMART attributes of a particular hard disk drive. SMART ( Self Monitoring Analysis & Reporting Technology ) is an interface between a computer’s BIOS (basic input/output system) and the computer hard disk. It is a feature of the Enhanced Integrated Drive Electronics (EIDE) technology that controls access to the hard drive. If S.M.A.R.T is enabled when a computer is set up, the BIOS can receive analytical information from the hard drive and determine whether to send the user a warning message about possible future failure of the hard drive.
  2. HDD Health - It’s is a full-featured failure-prediction agent for machines using Windows 95, 98, NT, Me, 2000 and XP. Sitting in the system tray, it monitors hard disks and alerts you to impending failure. The program uses Self Monitoring and Reporting Technology (S.M.A.R.T.) built into all new hard disks, and can predict failures on your hard drives. A host of alerting features include email, local pop-up messages, net messages, and event logging, while using no system resources.
  3. S.M.A.R.T. Monitoring Tool - smartmontools contains utility programs (smartctl, smartd) to control/monitor storage systems using the Self-Monitoring, Analysis and Reporting Technology System (S.M.A.R.T.) built into most modern ATA and SCSI disks.
With this Superb Tools you can boost your Hard Drive Performance at it’s best as well as get notified if the Software shows you any future Hard Drive Failure Warning. Moreover it’s recommended that you use any one of the above mentioned tool, don’t have multiple installation at a time.
Source: http://tech-baby.co.cc/2008/09/29/3-...th-at-its-best
- MrinTech :)
mrintech is offline
Old 29-09-2008, 08:06 PM   #2 (permalink)
spice it up
kapsicum's Avatar
Default Re: 3 Best Utilities to Monitor Your Hard Disk Health at it’s Best
though i m not clear dat u r suggesting to try all or any one of them ...i will try them one by one if it could really help in monitoring the HDD ...
thnks buddy..
kapsicum is offline
Old 29-09-2008, 08:23 PM   #3 (permalink)
Point Blanc
smart is inbuilt in HDD, the first two are separate softwares utilizing it to give feedback.
Third is also same tool as first 2 but it is from the company owning SMART. This is what I understood from his words.
acewin is offline
Old 29-09-2008, 10:14 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
Well I must say stick to third one. Better try the Other 2, but don't install all of them or any 2 of them running simultaneously
- MrinTech :)
mrintech is offline
Old 29-09-2008, 10:34 PM   #5 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Cool Re: 3 Best Utilities to Monitor Your Hard Disk Health at it’s Best
HDD Monitoring & Maintanance == "PerfectDisk"
Living for Learning & Learning for Living
Sathish is offline
Old 30-09-2008, 01:03 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
hmmmm .... nice 1 ..... bt only 1 is enough .......
... W H O T ...
ax3 is offline
Old 30-09-2008, 01:30 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Hmm, my HDD is working nice, some 76mbps read write
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 30-09-2008, 04:05 PM   #8 (permalink)
Project Halcyon V2.0
tkin's Avatar
Best Hard Drive Monitoring Cum Benchmarking Tool is HD Tune Free Version, also you can use the simplest possible tool named HW Monitor, that uses no system resources at all.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Hard thinking about Hard Disk power_8383 QnA (read only) 10 25-03-2008 05:14 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
Hard Disk Health manishji Software Q&A 7 21-10-2006 12:58 PM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by kool
