Old 28-09-2008, 07:32 PM   #1 (permalink)
Question Help Me
i wish to buy a laptop (dell Hp or compaq) for basic gaming with 3gb
ram a good graphic solution preferably the 8600gt my budget is 35-50k
kindly help me please give the model no and configurations
THANK YOU
anmol singh mzn 2008 is offline
Old 29-09-2008, 05:21 PM   #2 (permalink)
Default Re: Help Me
Check out the compaq CQ45-137 TX which is around 49k. Very Good configuration with a decent graphics card nvidea 9200GS and forget getting anything below 50k having graphics card you have mentioned 8600GT.
Regards
Ashwin
AshwinDR is offline
Old 29-09-2008, 06:46 PM   #3 (permalink)
Default Re: Help Me
what resolutions are to be expected with crysis with 9200gs
Old 29-09-2008, 06:57 PM   #4 (permalink)
Default Re: Help Me
Check this out dude.
Might give you more insight on the graphics card
http://www.notebookcheck.net/NVIDIA-...GS.9453.0.html
Regards
Ashwin
AshwinDR is offline
Old 30-09-2008, 01:29 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Help Me
800x600, low low and all low settings
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 01-10-2008, 12:32 PM   #6 (permalink)
Default Re: Help Me
should i buy the dell xps 1530 then
Old 01-10-2008, 02:02 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Help Me
Yes, that's awesome choice go wid it!!!
About me:
Old 09-10-2008, 07:23 PM   #8 (permalink)
Default Re: Help Me
Hi Dude,
Rather than going with xps 1530, have a look at HP dv5-1015tx lappy which had better config than a xps 1530. I have given a brief comparision with the xps in the below given link. have a look. I own this lappy too. If you have any questions on the same ask me i would answer if i am able to
http://www.thinkdigit.com/forum/show...970#post951970
Regards
Ashwin
AshwinDR is offline
- by kool
