Old 28-09-2008, 01:20 PM   #1 (permalink)
Default Upgrade suggestions
Hi guys I have decided to get rid of my old rig only cpu.
My budget 15k.Alredy have hdd,dvd rw,monitor.
After a bit of research i came up with foll:
Motherboard: Gigabyte EP31-DS3L 3.3k / Intel DG31PR
Processor: E7200 5.4K //fixed
RAM: Transcend 2x1GB DDR2 800MHz 2k
SMPS:CM 460 W 1.7k
Cabinet: ?
GPU: ATI 3850HD 5.6k [or hd 4670 will wait hope it cms soon]
Already 18k
Any suggestions for above config?
Also do tell me a low range cabinet.
wills sell off old mb,proc,cabby,ram for maybe app ~2k
effectively 16k now.
Plz suggest a cabinet ws thnking of iball worhorse?
waiting fr ur replies...
sahilshah1987 is offline
Old 28-09-2008, 01:30 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Upgrade suggestions
Zebronice Bijli comes for 1.3k I guess
Or yes, iBall workhorse is on sale(surplus, old stock) in lynx-india for just 0.5k(including VAT)!!!
http://www.lynx-india.com/index.php?productID=1514
Now that's a good deal don't you think^^!!!!
Hmm, you cud wait for the 4670 and 4650(both perform similarly, but 4670 is a tad costlier with GDDR3 memory). They will have lower(much much) TDP than 3850(by a big margin, havn't you heard 3850 has Overheating issues??)
And if u're gonna wait, then a E5200(I hope it comes soon) for 4k probably will be a very sweet deal, bringing your PC budget to ~15k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 28-09-2008, 01:53 PM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Well, go for that gigabyte P31 board. How did you manage to find one ? P31s are supposed to be rare in India from what I have seen and they OverClock very well compared to G31 and G33, and perhaps in the level of Q35, next to only P35.
And yeah, consider waiting for HD4670. Don't go for HD4650 - its around 600 rupees cheaper, but it has DDR2 instead of GDDR3 and has a little lower clock speed. Its just not worth the price difference.
You might want to wait and see if the Intel E5200 hits the market soon enough or not. It can cost 3.5K to 4K, it has 800MHz FSB, 2MB L2 Cache and 2.5GHz Clock Speed.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 28-09-2008, 02:03 PM   #4 (permalink)
I have yet to check if that gigabyte board is available.Will get to know soon.
Thats why i have added an option of Intel DG31PR mobo.
Do u have any other recomm at tht price range?
Old 28-09-2008, 02:07 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
No, it's sweet, whaever u've already considered
About me:
Old 28-09-2008, 02:45 PM   #6 (permalink)
The Smaller Bang
if that gigabyte board is not available, get gigabyte G31 instead of P31.
but never get intel original mobos.
Old 28-09-2008, 07:10 PM   #7 (permalink)
How abt this mobo priced at 2775 itwares
http://in.asus.com/products.aspx?l1=...72&modelmenu=2
Old 28-09-2008, 09:30 PM   #8 (permalink)
The Smaller Bang
As I said before, if he doesn't get P31, this is the next best choice. This is MUCH BETTER compared to DG31PR. But yes, P31 is a must try if he wants to overclock a lot.
Old 28-09-2008, 09:36 PM   #9 (permalink)
Who is he here or is it me
What do u think abt psu and cabby?
Old 29-09-2008, 05:39 AM   #10 (permalink)
The Smaller Bang
wth ? you are the same guy ? The style of writing was different in the first post and the post I replied to, so I thought you were someone else without bothering to look at the username
Old 29-09-2008, 02:18 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
iBall gamer with 400W PSU @ 1.7k
About me:
Old 29-09-2008, 07:52 PM   #12 (permalink)
Update:
Ga-P31-DS3l is avla ble at 3.4k will go with tht
Psu Cm390 @1.5k(dnt go by its less wattage it has great efficiency)
iball gamer cabinet @ 900 bucks
Thx metalhead gautham and comp@ddict .Will update once i get final rig
Old 30-09-2008, 01:40 PM   #13 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Anytime dude
About me:
Suggestions for Upgrade Ultra_Bloodshed Hardware Q&A 13 01-08-2008 07:43 PM
Need suggestions for mobo upgrade gulgulumaal Hardware Q&A 4 12-11-2007 06:17 PM
Upgrade Suggestions? devilz666 QnA (read only) 2 26-10-2007 03:49 PM
Suggestions for my upgrade Aparajith Hardware Q&A 2 28-04-2006 04:34 PM
suggestions :help to upgrade my pc!!! go_gamez Hardware Q&A 7 10-04-2006 02:07 PM
- by kool
