Old 28-09-2008, 11:44 AM   #1 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Thumbs down Help to upgrade my AMD Processor (939 socket)
I have an old gaming system with following configuration..
AMD Atholon 64 3500+ (Socket 939)
Asus A8 VN CSM Motherboard
DDR 400 2GB RAM
NVidia 7300 GT 256 MB (DDR2)
Now i have a plan to upgrade by Processor and Graphics card without changing my "Stable Mothreboard". (cost no bar)
One of my friend told that socket 939 AMD processor were gone out in the current market and i must change my motherboard too.
I want some opinons of Digitians.
Living for Learning & Learning for Living
Sathish is offline
Old 28-09-2008, 12:41 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: Help to upgrade my AMD Processor (939 socket)
You can't upgrade while keeping your current motherboard since all new CPUs are socket AM2 or AM2+ or (soon) AM3.
But as it is, your rig is pretty decent. You can definitely hold it for some time.
And since you said {cost no bar}, why not change mobo too ?
And yeah, since Deneb is soon arriving, I suggest you push on till january with your current rig.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 28-09-2008, 12:49 PM   #3 (permalink)
Sathish's Avatar
if i proceed to find socket 939 AMD 4800+..
lot of my collegues said that 4800+ has some heat issues..
is it true..
Sathish is offline
Old 28-09-2008, 12:54 PM   #4 (permalink)
Violent serenity.
Psychosocial's Avatar
Please change your mobo too.
I suggest an Intel config
Intel E8400 + MSI P45 Neo-F + Palit HD4850 512MB GDDR3 + 4GB DDR2 800MHz RAM
If you want to stick with AMD then ->
AMD Athlon 64X2 6000+ + some good 780 mobo + same as above
Psychosocial is offline
Old 28-09-2008, 01:57 PM   #5 (permalink)
The Smaller Bang
I still don't get the point of upgrading too soon. Even I am putting off my upgrade till deneb arrives. Its worth it.
And yeah, AMD 6000+ is a big joke. Nobody in their right mind would buy it for a gaming rig today
Old 28-09-2008, 05:52 PM   #6 (permalink)
Socket AM2 is must for your upgrades...Sell your old Socket 939 based board.
cool_boy4ua is offline
Old 28-09-2008, 08:38 PM   #7 (permalink)
Sathish's Avatar
Question Re: Help to upgrade my AMD Processor (939 socket)
ok..
one more last question..
is any major performance oriented difference between AM2 and 939.?
Sathish is offline
Old 28-09-2008, 09:28 PM   #8 (permalink)
The Smaller Bang
Originally Posted by Betruger View Post
ok..
Hell yeah.
And even AM2 is obsolete
Aaj Ke Zamane mein AM2+ miltha hai
But I still advice you to wait for AM3 to be formally out on January.
Knowing AMD, I am sure they will release an awssome cheap chipset for it soon, mostly with RV 730 intergrated graphics if we are lucky.
So wait. Its worth it.
System upgrade help needed harish_21_10 QnA (read only) 3 28-07-2008 11:48 AM
Need help to upgrade system raj_82_18 Hardware Q&A 1 26-10-2007 08:49 PM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
system upgrade readermaniax QnA (read only) 14 01-08-2005 11:19 PM
system upgrade!!! karthik316_2003 QnA (read only) 7 25-05-2005 02:01 AM
- by kool
