28-09-2008, 11:39 AM
Help needed selecting a LCD!
ok i understand that the best 19" is Dell SE198WFP but how good is the Samsung 943NWX?
and then in 20 inch how about Dell SP2008WFP....or any other suggestion for 20"?
tq
28-09-2008, 12:57 PM
Violent serenity.
Re: Help needed selecting a LCD!
Dell is the best.
19", 20" or 22"......Dell is the best.
28-09-2008, 02:47 PM
ok can HD4850 handle 1680 x 1050 resolution?
28-09-2008, 02:58 PM
tq
samsung 943NWX ..is fair enough ..but lacks a DVI input ..which is much better than old analog VGA input.especially when going for HD4850 DVI input will make a difference ...
dell is better in all terms ...but deciding factor can be ur budget ..another good monitor(atleast feature wise ..as there are no reviews out yet ...since its very new monitor ) can be benq E2200 HD/HDA ...which is the only 22" monitor to support full HD ..@13k
samsung is good quality wise ..but lacks feature wise so will always come second or thrid after dell and viewsonic ..
feature wise viewsonic monitors are very good too ...and are available for much cheaper price than dell if tight on budget ..u can go for them ..
HD4850 can handle majority games upto full HD pretty nicely ...but not all of them ...infact i beleive 19" in itself is a bottleneck for HD4850 ..any game u throw on it it plays happily at all settings max @19"..so to really extract performace out of HD4850 u will need 22" monitor ...
chilling.....
28-09-2008, 06:30 PM
Violent serenity.
^^True.
28-09-2008, 06:40 PM
ok so its mostly going to be Dell SP2008WFP....20"!!
28-09-2008, 06:44 PM
Violent serenity.
If budget permits then 228WFP other 2008WFP will be awesome.
28-09-2008, 10:22 PM
o yesh . usless its old crysis crying out loud at ultra high settings.
20 inch monitor could bother a little while reading than a 22 inch one.
29-09-2008, 01:19 PM
Norms Buster
How is the Viewsonic brand ?
29-09-2008, 02:12 PM
Violent serenity.
Amazing VFM.....I am using the VA1912w and the monitor is just amazing. It might have got average reviews but I find it to be very good.
29-09-2008, 02:19 PM
i agree with u on that ....atually all the review sites are from abroad ...where they have so many options for brands ..when we come to india ..we have very limited brands ..i will always keep samsung and viewsonic as second best after dell ...they cheaper than dell ..its not like they are extremelly inferior to dell
but viewsonic on higher side ..cos featurewise its more better than samsung
chilling.....
29-09-2008, 02:32 PM
i bought the Dell SE2008WFP!!!!!!!
here is the pic!
29-09-2008, 02:40 PM
EXIT: DATA Junkyard
ViewSonic and Dell are recommended for gaming panels, Viewsonic is awesome VFM too..
4850 will hold out to 1680x1050 and even 1920x1200 with one or 2 settings down a bit(n i mean only a bit)..but OCing solves that too.....
29-09-2008, 02:54 PM
Violent serenity.
here is the pic!
Awesome!!
You just bought one of the best things of your life
29-09-2008, 02:56 PM
EXIT: DATA Junkyard
How's Dell vs View Sonic in performance terms keeping VFM in mind?
29-09-2008, 07:12 PM
thanks KP!
29-09-2008, 09:23 PM
I would recommend the ViewSonic's 22" VX2235wm widescreen LCD
which I bought a month back & must say, I am very pleased with its
performance
features:
DVI port
Built in stereo speakers (ok qual)
2ms response time
4000:1 contrast ratio
read the review:
http://www.hardwarezone.com/articles...?cid=5&id=2456
I was going to buy a dell with integrated usb ports & web cam which costed 16200
but when i called dell & they quoted me the final amount of 18K+ (after adding taxes, octroi)
I changed my mind & instead bought the above mentioned monitor for 13200
great VFM, i say
30-09-2008, 12:37 AM
Violent serenity.
^^True......for 13k, its awesome....and 2ms response time is just great for games and movies.
30-09-2008, 01:07 PM
#19 (permalink)
EXIT: DATA Junkyard
Yes, ViewSOnic is good.
I mean 19" VX 1940 1680x1050, 2ms is @ 10.5k, what more do you want??
30-09-2008, 04:09 PM
#20 (permalink)
Project Halcyon V2.0
DELL is THE best performer.
Viewsonic is THE best VFM.
End of Story.
What's your budget?
Project Halcyon v2.0:
30-09-2008, 04:54 PM
#21 (permalink)
Violent serenity.
^^LOL....he already bought the LCD.
01-10-2008, 12:46 AM
#22 (permalink)
OOPS, guess I'm a bit hyper now, my RIG is just around the corner, first time to play DMC4 maxed out in a 22" LCD (I hate Crysis, just so sick of it, man I need something new. Eg-GTA4)
01-10-2008, 01:08 AM
#23 (permalink)
its really difficult to say about the performance difference cos looking at something everyone can have a different perceptions..and there are no set criterions...but LCD monitors these days are becoming good ..i haven't heard any problem of pixels or anything of that sort ..so far ...backlight could be a problem in few monitors ...
but keeping VFM apart ..i think dell can be at the most 7~10 % better ..and thats a bit stretched i guess ..thats maximum...and its my guess i have no theory or link to support this point !
there is not a difference of day or night between any monitors that are out there ...so anyone who would be buying viewsonic will be very satisfied ..and wouldn't find a difference in picture quality unless both monitors dell and viewsonic are kept side by side ..i can tell u this cos our friends tried this out ...and yes u can say we don't have perfect eye for difference ..but yes thats what is the case with average user ...i for being one average user...
so considering these fact ..i think if anyone on stiff budget.....should go for viewsonic 22" by all means i mean they are available for about 12.5k these days ..thats like about 2k less ...its the same thing ...2k more for may be 5% or 7% or 10% (far stretched) better on dell ..VFM
but in 19" the obvious choice should be dell ...cos there is no price difference ...
chilling.....
01-10-2008, 01:11 AM
#24 (permalink)
+1 to that, and Wish you a Very Very Happy Diwali, imgame2.
01-10-2008, 10:31 AM
#25 (permalink)
i thought u are going away for durga pooja ...did not know u will be going away till diwali ...but happy durga puja and happy diwali to u ...if that is the case ...
chilling.....
01-10-2008, 11:21 AM
#26 (permalink)
here is the pic!
Congrats on your buy. Even I am considering the Dell SE2008WFP. I have a couple of questions to ask on this.
1. Which vga card do you use? I currently have a 7600GT. I wonder whether it will be enough to run the monitor at its native resolution of 1680x1050.
2. The screen is glossy on this monitor. How much does the glare bother you? Is it a big issue?
TIA!
06-10-2008, 08:23 AM
#27 (permalink)
@paraman
1.sry i cant help you here since i have not got my ordered Sapphire HD4850 card yet and im using my old system.ill get my card within 2 days hopefully so ill let you know.
2.glare shouldn't be an issue coz with the sunlight rays falling on my monitor im able to adjust.
and guys i have a Q!
the text and images on my screen are not sharp and focused...is it because im using my OLD 64MB on board VGA card @ 1680*900?
06-10-2008, 10:31 AM
#28 (permalink)
Violent serenity.
TIA!
1. SURE. Even a 7300GT should do it. 7600GT will be a good companion for the LCD.
2. Not a big issues unless u sit directly opposite to a tube-light  .
06-10-2008, 11:37 AM
#29 (permalink)
EXIT: DATA Junkyard
@paraman
Try Clear type...it helped me a lot......sharp and focusd is what u want rite...then go as i said..google.CLEAR TYPE
09-10-2008, 11:55 AM
#30 (permalink)
@RMN & KPower Mania
Thanks for your replies!
