Old 25-09-2008, 07:00 PM   #1 (permalink)
Simpsons rox
Default externall hdd is getting hot??
i recently bought a WD elements 3.5" external hdd 500gb. i have kept it on top of my cpu.
the room is not air conditioned.
the hdd gets hot after a few hours of keeping it on. i can touch it . but still it is way hotter than room temp.
is this normarl? what can i do to cool it if it aint?
also it is under warranty so what shuld i do?
do internal hdds also get so hot?
T.G. Praveen
A computer program does what you tell it to do, not what you want it to do.
Visit my site at www.praveen.co.nr
tgpraveen is offline
Old 25-09-2008, 07:08 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: externall hdd is getting hot??
Ias it normal............ I don't know........
I've used 3 external FDDs till now...........3.5"...........by maxtor, WD and Seagate (500GB each).........all of them gets hot while being on for several hours.......
I think other forum members may throw light on this........
Man..........it gets hot like hell..............after using ur pc like executing tasks like watching movie from interrnal HDD, palying games for even 2 hrs makes it enough hot to fry an egg
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 25-09-2008, 08:51 PM   #3 (permalink)
Simpsons rox
well sine mine is external and gets hot i could probably make papads
off to get some papads
seriuosly though others pls comment
T.G. Praveen
Old 30-09-2008, 04:35 PM   #4 (permalink)
static_x's Avatar
Use Sentinal Hard Disk Monitor (software) to monitor the condition of your HDDs. We can check the External HDDs by touching 'em so you can say that its getting hot but its okay..i mean at times they reach +55C or higher....
static_x is offline
Old 02-10-2008, 12:57 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
i think, more hdd gb`s more HOTTER they r ........
... W H O T ...
ax3 is offline
Old 02-10-2008, 03:00 PM   #6 (permalink)
Wise Old Mouse
mrintech's Avatar
better have any one of the applications installed in your PC to check hard drive stats: http://tech-baby.co.cc/3-best-utilit...th-at-its-best
- MrinTech :)
mrintech is offline
Old 05-10-2008, 12:31 AM   #7 (permalink)
Point Blanc
yeah really check the temps with the above softwares.
I got WD Passport nad also ahve used Elements, they do not go very hot may maxed to 35-40 but not more anything more than that is not good in general I would say.
acewin is offline
Old 05-10-2008, 11:34 PM   #8 (permalink)
M$™ Certified Spammer
entrana's Avatar
it is supposed to get hot. its just an internal hdd with a case and a usb interface. expect it to run at even 50 degrees C. but u shudnt use externals that long . many people have issues of data corruption. externals arent supposed to be used for many hours.
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 06-10-2008, 10:01 AM   #9 (permalink)
static_x's Avatar
I Talked to Seagate CC service and they told that you can run the external HDs for any period of time, provided they're kept in open and non humid atmosphere.
static_x is offline
Old 06-10-2008, 10:30 AM   #10 (permalink)
entrana's Avatar
u wanna bet? google this prob man. many people will start having problems with overuse of externals.
entrana is offline
Old 06-10-2008, 10:41 AM   #11 (permalink)
static_x's Avatar
I'm not disagreeing you mate..i'm telling you what seagate service people told me....BTW i'm using my LaCie Externall HD (500GB) constantly for the past 1 year and no problem yet....It remains ON whenever I'm using my system...
Confirmed it again from Seagate CC...upto the temp of 70 C it is perfectly okay..
static_x is offline
