24-09-2008, 07:34 PM
Mobo...????
Hi Evry1..
I'm buying a new PC..I've settled for this but i'm confused abt Mobo..
Core 2 Duo *3.0 GHz E8400
Transcend DDR 2 2 GB 800 Mhz
Lite - On Lite-On 20X Sata
Corsair 450W Power Supply (VX450W) or CAN I GO FOR LOCAL PSU??
Zotac 9800 GTX
Cabinet
Monitor - Dell 19" SE198WFP
Which mobo shud i chose...i want PCi-e2 slot and budget is below 8k..
is P7NSLI PLATINUM a good choice??
24-09-2008, 09:13 PM
-----ATi-----
Re: Mobo...????
Go for a branded PSU. You wont be able to run the 9800GTX properly on local PSUs..
http://twitter.com/akshayms
24-09-2008, 09:28 PM
Re: Mobo...????
Originally Posted by gani.slimshady
Hi Evry1..
Zotac 9800 GTX
Cabinet
my question why go for outdated/expensive 9800gtx which is simply costly and HD4850 a 9.7k card can beat it everywhere ....
BTW how much u are getting it for ...if its around 15k ..simply go for ..HD4870 for 17k one the most VFM card u can ever get ...it will beat 9800gtx to death
never even think about running a 9800gtx level card with local PSU ...ur monitor will not get any display in all probability ...so u need a good and Vx450 is very good infact best in that price range ! which will give u constant power a gfx card needs ..
if u go for an ATI card like HD4870 or perhaps a HD4850 ...then u can go for Asus P5Q for 8k ..or for ASUS P5Q pro for 8.5k ......if u want to crossfire ...
chilling.....
24-09-2008, 09:35 PM
Searching for Anti-Matter
Re: Mobo...????
Go with corsair psu .. forget local psu if u r/will-be using 9800gtx/4850
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
24-09-2008, 10:09 PM
The Black Waltz
Re: Mobo...????
Go for the Palit HD4850
Go for ASUS P5Q or MSI P45 Neo F
The MSI board costs just Rs 5.5K. But the P5Q is better.
Always go for a branded PSU. Other PSUs don't deliver the power according to the rating.
#krow @ irc.freenode.net
24-09-2008, 10:26 PM
Violent serenity.
Re: Mobo...????
Hi Evry1..
Zotac 9800 GTX
Cabinet
E8400
Transcend 2x2 Gb DDR2 800MHz RAM
Lite On LH-20-A1P
MSI P45 Neo-F
Palit HD4850 512MB GDDR3
24-09-2008, 10:46 PM
Re: Mobo...????
Originally Posted by KPower Mania
E8400
Lite On LH-20-A1P
MSI P45 Neo-F
don't u think for 8k budget ...Asus P5Q is better option than MSI p45 neo
chilling.....
24-09-2008, 11:12 PM
Violent serenity.
Re: Mobo...????
Think about it........... MSI P45 Neo-F and ASUS P5Q are both P45 based mobos. Both have around the same features and same performance. Both are awesome OC'ers. Both have very good features. Both are VFM. So why spend 2k more for a marginal performance difference ?? But if he really wants to spend all of that 8k then I cant argue that ASUS P5Q is an awesome board.
I was suggesting VFM.
BTW, go for Corsair VX450W or CM EP 600W.
That is bcoz VX450W will require a Sine Wave UPS. If you dont have a Sine Wave UPS then you will have to use your PC without a UPS. So if you dont have a sine wave UPS and dont want to buy one, go for CM EP 600W.
I run my PC without a UPS as there literally no power-cuts here  .
Reason: Automerged Doublepost
25-09-2008, 12:22 AM
Point Blanc
Re: Mobo...????
same as KPower I say, because when thingking of UPS APC makes you cry. 650VA in around 3K and 800VA in around 5.2K, saving money does matter.
25-09-2008, 01:20 AM
Re: Mobo...????
first he need to tell people here what UPS he has or what he intends to buy before putting that as a consideration for the budget
25-09-2008, 07:22 PM
15.0 GHz
Re: Mobo...????
instead of zotac 9800GTX go for Palit HD4850.
and get MSI P45 Neo F mobo.
25-09-2008, 07:27 PM
Violent serenity.
Re: Mobo...????
Already posted..../
25-09-2008, 07:30 PM
15.0 GHz
Re: Mobo...????
sorry not seen
25-09-2008, 10:47 PM
EXIT: DATA Junkyard
Re: Mobo...????
Hi Evry1..
Zotac 9800 GTX
Cabinet
No local PSU for you
MSI P45-NEO F @ 5.8k is best bet
26-09-2008, 07:12 PM
Re: Mobo...????
Does MSI P45 Neo-F has PCI-E 2 slot??
26-09-2008, 07:31 PM
Re: Mobo...????
offcourse its P45 chipset ..so it does have PCIex 2.0 like any other P45 chipset based mobo ...
chilling.....
27-09-2008, 07:51 AM
The Black Waltz
Re: Mobo...????
It has a PCI E gen2 x16 slot. Or if you mean to ask if it has 2 of these slots, no it has only 1 slot.
27-09-2008, 02:40 PM
Violent serenity.
Re: Mobo...????
He meant PCI-e x16 2.0 which the P45 Neo-F has.
27-09-2008, 02:49 PM
#19 (permalink)
Excessive happiness
Re: Mobo...????
I wonder how you manage to answer these questions.. Thats so smart....
@thread_starter:
Go for MSI website and have a look at the spec.. u may find the complete detail....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
27-09-2008, 07:11 PM
#20 (permalink)
Violent serenity.
Re: Mobo...????
@thread_starter:
Was that meant to bash me ?? Just tell openly, I wont mind  .
28-09-2008, 01:42 PM
#21 (permalink)
EXIT: DATA Junkyard
Re: Mobo...????
We've got smart guys here, whadd else do u xpect?
