Old 24-09-2008, 07:19 PM   #1 (permalink)
RMN
Default My new PC'c sonfig+prices
hello guys im new here.
after a bit of researching ive decided on my new pc's config.
Q6600 @8600RS
Intel DP35 @5500RS
Radeon HD4850 @ 11000RS!!!
2 GB RAM DDR2 @2000RS
now can you guys tell me if im paying a lot for this esp. for the HD4850 coz ive seen it for 160$ on newegg and ebay.im staying in Kerala,Cochin.
and if there is anyone staying in Cochin can you please let me know a good store esp where i can get the HD4850?
thankyou
RMN is offline
Old 24-09-2008, 07:51 PM   #2 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Default Re: My new PC'c sonfig+prices
Who is manufacturer of hd4850.
Its price is around 10.8 to 9.9k!
I got my sapphire hd4850 @ 11.5k.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Last edited by Power_user_EX; 24-09-2008 at 07:52 PM. Reason: Automerged Doublepost
Power_user_EX is offline
Old 24-09-2008, 08:03 PM   #3 (permalink)
Q6600 @8600RS
Intel DP35 @5500RS
thankyou
other prices seems fine to me ...but why go for intel DP35 mobo ..get MSI P45 neo ....better chipset ...and it will help u overclocking @ 5.8k ..
go for palit Hd4850 available for 9.2 to 9.5k depending @ the place u are ..and never compare price here and in US its never simple currency conversion ...but the price i m telling u is the best u can get ...and i would suggest u to go for palit version of card i.e,Palit HD4850...comes with latest bios runs cool and quiet and faces no problem ..atleast 8 people by now i know have bought this card including me and running it without any problem ...so look for that ...
also u did not mention u need to have a good PSU for ur card atleast CM 500 W but i will suggest u go for corsair vx450 for about 3.2~ 3.4k....
chilling.....
imgame2 is offline
Old 24-09-2008, 08:40 PM   #4 (permalink)
RMN
thank you guys.
yes i was initially going for the P45 but its not available anywhere in Cochin.i even found a hd 4850 in 7th or 8th store i checked!
btw what i understand is that the p45 is pretty much the p35 except for the updated crossfire?
and im bit of a noob so i have a few Q's
-isn't cross fire connecting 2 graphic cards in one system?
-i would just need ONE PSU you right?i was thinking abt a 550W or is 500 enough?
and would i need any extra cooling products for my config apart from the stock items?
tq
oh yeah btw any reliable online shopping sites you ppl recommend?
RMN is offline
Old 24-09-2008, 09:16 PM   #5 (permalink)
thank you guys.
tq
yes P35 is almost the same except addition of PCI-ex 2.0 which gives better performs with gfx cards albiet may be only 5~7% better and along with ICH10 controller hub ..in one go it wouldn't be great by the look but it can be make ur system about 5~10% faster overall if not more ...and P45 is newer chipet ...if u can get a faster system just by spending 300 rupees more ...why not ...?? its totally worth in my opinion!
crossfire is technology that lets u add two cards (ATI cards only) in one system ...but neither the board u are thinking to buy nor the board i m suggesting has crossfire ..means two graphics slot ...so u don't have to worry about it !
going for MSI or ASUS mobo gives u the flexibility to overclock ..if u want to later on ...intel doesn't give u any overclocker feature ...
and yes u will need only one PSU even if u use two gfx cards but then u will need a PSU with higher wattage ...thats all ...
also u will need to have a good PSU not the ones u get with cabby for HD4850 u will need atleast CM500W @ 2.7k approx
or my suggestion if u can spend go for corsair Vx450W @ 3.2k
and higher wattage comes for higher price ....
online shopes -
1.http://www.lynx-india.com/
2.http://theitwares.com/
3.http://techshop.in/
don't go on the website of the first two ...but they are the best u can get in india and they are credible many people in our forum can vouch for them as they have bought stuff from there ....
just look for the stuff u get cheaper on whichever site ...they are good !
chilling.....
imgame2 is offline
Old 24-09-2008, 09:22 PM   #6 (permalink)
harryneopotter's Avatar
For online Shopping ... www.theitwares.com and www.lynx-india.com are well known sites in india with good pricing.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 24-09-2008, 09:31 PM   #7 (permalink)
off the topic now that u have got a new system ..u can update ur siggy perhaps ...
chilling.....
imgame2 is offline
Old 24-09-2008, 09:51 PM   #8 (permalink)
@imgame:
yea i can ...but config in siggy is out now i think ... but still ..its not bad untill i find something good. thnx for the suggestion ..
Y ??
Old 24-09-2008, 10:26 PM   #9 (permalink)
RMN
thanks again guys...really helpful!
btw im not clear with the PSU.
i just need one 500W PSU for my whole system right?
what is Front Side Bus?and does these online shoppers provide warranty?
and what about the coolers?should i get another FAN for my GFX card or processor?
tq
RMN is offline
Old 24-09-2008, 10:45 PM   #10 (permalink)
tq
yes u need just one PSU ...and this one is good enough for u ! look here
http://www.newegg.com/Product/Produc...82E16817139003
...well u already have a PSU in the comp ..but when it comes to GFX card ..they need costant power ..hence u need a better PSU which can provide u that ...
what do u want to know about FSB ? its front side bus !
well they do say provide warranty and the first two (itwares and lynx ) are good as i said before ..they are credible ..and yes they provide warranty ...u will have to ask them how they provide it ...at max if any problem comes u can send them back ....and get ur RMA ..
i think u will not need any aftermarket cooler if u are not overclocking ...the Stock fan is more than enough ...
for palit HD4850 again i don't think u will need another cooler or fan ...even if u overclock it ...atleast i don't need it ...
and other coolers u might need if u want to pull down ur system temperatures ...but i don't think u will need them ....
chilling.....
imgame2 is offline
Old 24-09-2008, 10:50 PM   #11 (permalink)
For the PSU thing ... U should opt for Corsair VX450 for about 3.2 k and its the BEST in this range. It will be enuf for a Single Card Setup.
U can avail warranty for the stuff bought from online shops at their respective Service Centers. (i mean if u buy a palit card .. u can take it to a palit service center in case of any mishap.)
Front Side Bus of FSB (as commonly known) is the Data Bus on the motherboard through which different components communicate with each other. (u can imagine it as Roads in a city which connect traffic from various parts of the city to each other...but here DATA is the traffic) . So faster the FSB, faster the data travels b/w various components (like from RAM to Proccessor etc) .
If u dnt plan to overclock ur setup ..then u dont need aftermarket coolers for ur Gfx card or porccessor. But u can additional Cabinet Fans to improve airflow in the Cabniet.
Hope it helps.
Y ??
Old 24-09-2008, 11:32 PM   #12 (permalink)
RMN
thanks again....
so this is what ive decided on..
Palit HD 4850 512MB DDR3 256Bit 9750
MSI P45 Neo-F Intel® P45 Chipset 1333 FSB 5850
Quad Q6600 2.4 GHz(8MB L2 cache 2.4Ghz 1066MHz FSB) 8900
(G0 Stepping Guaranteed)
Transcend DDR 2 2 GB 800 Mhz 1900
Samsung LCD 19 '' 943NWX 9600
CoolerMaster RS-500-PCAR Extreme Power 500W 2850
how is it?now can you help me out with a case?i believe i wont need a hi-end one.
RMN is offline
Old 24-09-2008, 11:56 PM   #13 (permalink)
thanks again....
its cool but i think u should consider buying dell 19" LCD ...for 9.7k ...it has DVI port which is absent in 943NWX ..can buy it from dell website ...but i would say buy it from local dealer will give u good price ...and dell LCD's are best out there ...with absolutely amazing service support ..they can replace full monitor if there is single dead pixel ...(called panel warranty ) ..now thats what i call warranty ...
whats ur budget for cabby ....and why are u not considering Corsair Vx450 as PSU ...?? @3.2k ...???
chilling.....
imgame2 is offline
Old 25-09-2008, 06:49 AM   #14 (permalink)
Violent serenity.
Psychosocial's Avatar
thanks again....
If you want a gaming PC, I suggest you opt. for a Intel Core 2 Duo E8400 rather then a Q6600 as gaming is better with higher frequencies. The two additional cores wont help you much in gaming. But if you want your PC for abusive multi-tasking then Q6600 will be a better option.
I also suggest you go for the Dell's 198wfp 19" LCD as it performs better than the Samsung's and costs the same money.
BTW, which UPS are you using ?? If you dont have a sine wave UPS then the Corsair PSU will compatibility issues. But well, you can run your PC without a UPS (like I do) if you dont get frequent power-cuts and then the Corsair's PSU will run just fine.
But, if you want to run your PC with a UPS then do tell us which UPS you are using. If it aint a sine wave one than stick to CM EP 500W
Psychosocial is offline
Old 25-09-2008, 09:31 AM   #15 (permalink)
RMN
hmm...Dell 198wfp...ill check the price at my store.how are the ones from AOC?
and since im reaching my budget limit i was wondering if id get a good case for around 2000rs!i was thinking of Zebronics Antibiotic.
and i considered CoolerMaster RS-500-PCAR because its a bit cheaper and its 5ooW.isnt it a good choice?
i have a Numeric Digital 600 Plus UPS.
and the reason i chose Quad Core is that my primary use is of software's such as PS,3dsMZ and Maya.i am an amateur Multimedia and Graphics developer.and then comes Gaming.
tq
RMN is offline
Old 25-09-2008, 10:06 AM   #16 (permalink)
Violent serenity.
tq
Q6600 seems a beeter choice.
RS-500-PCAR is a very good PSU...... stick with it as your UPS aint a sine wave one .
Go for the CoolerMaster Elite 330 cabinet for around 1200/- ....... just look at pics of that cabinet and you will surely buy it. Awesome performance and killer looks at a terrific price.
Whatever you do, get the Dell ones. AOC makes mediocore LCDs..... nothing great.
All in all, the PSU is good...... go for CM Elite 330 cabby ........Dell will be the choice for LCD.
Old 25-09-2008, 11:59 AM   #17 (permalink)
RMN
btw any idea whats the diff bet Dell SE198WFP 19" Widescreen Flat Panel Monitor and E198WFP 19" Widescreen ?
RMN is offline
Old 25-09-2008, 12:28 PM   #18 (permalink)
Violent serenity.
I dunno the exact difference but SE has some Ultra-Sharp technology and stuff like that and is more expensive than the other one..... better stick with the cheaper one coz the performance difference is hardly visible unless you keep both the monitor side-by-side.
Old 25-09-2008, 12:33 PM   #19 (permalink)
I would definitely suggest you change the PSU. Corsair VX450W is the best and way better than CM 500W.
Also if you have a little extra budget to spare change the RAM from Transcend to Corsair, GSkill or OCZ.
Dont ever go for Zebronics Cabby!!! They are pathetic!!! I am stuck with one... My Mobo doesnt fit the Cabinet, the f*&!ing screws that came along with the Cabby are too small!!! So i have to keep the CPU lying on the ground on one side!!!!
Also Q6600 is good but almost becoming obsolete!!! Q9450 is a better choice in Quads. And E8500 or E8400 is the best you can go for in Dual Cores!! But i think Q9450 may sctrech your budget!!
hell_storm2006 is offline
Old 25-09-2008, 12:53 PM   #20 (permalink)
Violent serenity.
-->> I agree that it performs better but atleast read my previous posts and understand the reasons why I suggested him to go for the CM EP 500W in place of Corsair.
-->> The difference will be hardly visible in a mid range grafic designing/gaming PC. Its more visible in enthusiast level PCs instead. But no doubt Corsair, OCZ, GSkill RAM's performance....... absolutely top-notch.
-->> Which Zebronics cabby you have ?? AFAIK there are some really good budget cabinet models available from Zebronics. Ever saw Zebronics Bijli, Krissh and Antibiotic cabbys ?? They are really good. But yes, there are some models which are complete bull-sh1t.
-->> Correct!!!
@RMN
Go for the CoolerMaster Elite 330 cabinet as suggested before.
Last edited by Psychosocial; 25-09-2008 at 12:54 PM. Reason: Automerged Doublepost
Old 25-09-2008, 02:02 PM   #21 (permalink)
RMN
yes,so im almost done with my shopping list!!!thanks you you ppl!!!!!
Palit HD 4850
Dell SE198WFP 19"
btw what is G0 Stepping?and how do you rate my config?mid range?
RMN is offline
Old 25-09-2008, 02:07 PM   #22 (permalink)
Excessive happiness
furious_gamer's Avatar
Palit HD 4850
Dell SE198WFP 19"
I rate ur rig as poor... Dude just get E8400/8500 if u want some gaming.... Most of the users was suggest you to do so, but u still seem to be walk in ur way....
E7200 itself easily beat the Q6600......
Just change that and ur rig will be a mid-range gaming bull.....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 25-09-2008, 02:26 PM   #23 (permalink)
Violent serenity.
Actually, gaming will take a second step on this config. Its mainly for multi-tasking where Quads are better.
@RMN
I suggest you extend your budget and buy a Q9450 but if you cant, then go for this. It looks awesome. Just dont forget to OC the Q6600.
Old 25-09-2008, 02:35 PM   #24 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Palit HD 4850
Dell SE198WFP 19"
G0 stepping allows higher OCing, happy OCing.
And if you get the Q6600 to 3.2-3.4GHz and buy this:
OCZ 2GB 1066MHZ DDR2 @ 4k
Then, your rig is awesome!!!
About me:
http://about.me/preetam_nath
comp@ddict is online now
Old 25-09-2008, 02:45 PM   #25 (permalink)
RMN
yes Gaming is not my primary use but then is Gaming going to be BAD in this?
RMN is offline
Old 25-09-2008, 02:49 PM   #26 (permalink)
Excessive happiness
Sure..(By some negligible FPS...) but since this is not primary for Gaming.. this is OK..
PS Request
Old 25-09-2008, 03:10 PM   #27 (permalink)
RMN
ah then its fine coz im not the Crisis or COD kind of gamer.....the only games im looking ahead are GTA4 POP and MAFIA! so as a gamer this is sufficient!
RMN is offline
Old 25-09-2008, 03:19 PM   #28 (permalink)
Excessive happiness
GTA4... I m too.. but with such ****ed up rig... A 7600GS will do that?
Anyway nice if u get that rig and put it in some action.....
Advance wishes for ur purchase...
PS Request
Old 25-09-2008, 03:23 PM   #29 (permalink)
Violent serenity.
Its not gonna be all that bad. YOu will just have 10-15FPS less than a good C2D but that is ok. Anyways, todays games are more GPU based rather then CPU
Old 25-09-2008, 06:29 PM   #30 (permalink)
RMN
and one last thing(hopefully)...ive decided to buy my stuffs off ITwares.so its reliable right?anyone who has purchased anything from them?
RMN is offline
Prices amitash QnA (read only) 2 20-02-2008 03:02 PM
Prices sachin_libra Hardware Q&A 9 31-01-2007 08:41 PM
DDR prices to go up or down? chesss Hardware Q&A 4 08-03-2006 06:03 PM
Need to know some prices Delpiero QnA (read only) 2 03-01-2005 09:31 PM
PS2 Prices tushar_novice Gamerz 5 03-09-2004 02:29 PM
