Old 24-09-2008, 11:17 AM   #1 (permalink)
Unhappy SATA Drive not recognized
I have one old PC with this motherboard. It clearly says it supports SATA II 3Gbps drives, and has 4 SATA ports.
I bought a Western Digital Caviar SE16 640GB SATA II drive.
I installed the ULi M1575 SATA driver that comes with my motherboard (ASUS).
I hooked up the SATA drive properly (power cable + SATA data connector to my MBoard), and it didn't get detected, even after repeated attempts.
Even the BIOS raid utility could not detect the drive at all.
I'm pretty sure it's not a power problem since I detached my working DVD-RW's power supply and fed it into the drive.
Any clues?
(Note: I have an IDE HDD which I boot from)
[OS: XP SP2, CPU: Intel 3.2GHz P4, Ram: 1GB DDR2 667, HDD1: IDE Seagate 80GB).
GauravCJ is offline
Old 24-09-2008, 12:07 PM   #2 (permalink)
Default Re: SATA Drive not recognized
i do think that you have tried with ide hdd removed and all addtl components removed..
u might have to return the hdd as it could be faulty
realdan is offline
Old 24-09-2008, 12:45 PM   #3 (permalink)
First are you trying to do a fresh install of windows after adding the SATA drive??? Or was OS already installed when you added the hard disk???
hell_storm2006 is offline
Old 24-09-2008, 07:23 PM   #4 (permalink)
Os was already installed on my IDE HDD. This disk was meant to be a secondary storage drive.
GauravCJ is offline
USB Flash drive Not Recognized sushantvirdi Hardware Q&A 2 25-07-2007 11:04 AM
160gb external hard drive not recognized parheez Hardware Q&A 1 07-07-2007 06:18 AM
usb hard drive is not recognized choklate_007 Hardware Q&A 1 28-11-2006 07:14 PM
USB hard drive is not recognized choklate_007 Hardware Q&A 2 26-11-2006 09:43 AM
iPod not recognized on computer, appears as removable drive. Tallywacker Hardware Q&A 6 03-03-2006 03:04 AM
