hello guys out there i was just wondering if you could help out nobies like me in overclocking standard parts.....
my system specs:
c2d e4500
2X1gb ddr2 corsair jetram [667mhz]
160 gb hdd wd
xfx nvidia 8600gt 512mb gddr2
zebronics lava pc case with psu......
i know it is a overall sad config but i was wondering if you could help me out in overclocking this rig....
my system specs:
c2d e4500
160 gb hdd wd
Y u create a new thread.... Just edit ur existing thread will make it readable to us...
Anyway jusz mention ur Mobo man....
e4500 is 2.4GHz... right.... I'll try OC my E4600 and then tell u how far ir goes...
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ Updated : superteekz_V2 ROM for XXKPQ.
lol you will be surprised to know my motherboard intel 945gcz.... hey i tried to overclock with riva tuner but memory clock still not increaseing i..e comp hangs when i increase mem clock
Intel Mobos are not good for OC... OK.. If system hangs after OC ur gfx card means u OC above the cards safe limits....(I hope so)... So, just OC by lil increase like if the default clock is 640MHz, then increase by 5 or 10 MHz.. and look for stability... Then report here...
hey thnx raj but do you think my problem lies of ocing my gfx card with my psu?????
i only have a 450w bundled psu with my pc case zebronics lava maybe if i get a better pc case then??
Sure.... get atleast a 500W PSU or a Corsair VX450W... Better in case of OC....
hey fellows ummm... no i have an intel original mobo dg945gcz and i dont think it will not overclock........... 1 more thing i wanted to ask i am getting an asus x38 chipset with a evga 8800gts 320mb @ 8k hws that????????????????????????????????????????? will i be able to run it on a 450w psu? with pc case....
i would like to overclock it also will i be able to do that??.....................
or my best bet would be a evga 9600gt with a asus x38 for 6k???
how are u getting 8800 gts and X38 mobo ..i guess its second hand ...??
u will need something like coolermaster 600w or corsair vx450 ....to give sufficient power to mobo and gfx card in case u overclock both ...
my suggestion go for Vx 450
dude ask the question at one place ...it will be answered ..have faith and keep patience ...
chilling.....
Reason: Automerged Doublepost
