Old 23-09-2008, 10:40 AM   #1 (permalink)
PSN~ftw
NoasArcAngel's Avatar
Question HELP IN ocing 8600gt
hey guys i have a nvidia xfx 8600 gt card with 512 mb gddr2 ram i tried overclocking the card with ati tool but i am not able to go increase my memory clocks higher than 465 mhx effective 962.800 ..my core clocks are 680 mhz and shader clocks 1504mhz.. plz help me i have an intel dg945 mobo zebronics lava pc case with psu alongwith core2duo e4500
NoasArcAngel is offline
Old 23-09-2008, 12:08 PM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: HELP IN ocing 8600gt
Use Riva Tuner to overclock ur gfx card that they provide the safer limits of ur card..
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 23-09-2008, 01:12 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Check Official OVERCLOCKKER'S
About me:
http://about.me/preetam_nath
comp@ddict is online now
Old 23-09-2008, 01:30 PM   #4 (permalink)
PSN~ftw
Talking Re: HELP IN ocing 8600gt
got the rivatuner and tried to overclock but still memory clocks wont go higher!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!11 than 450mhz game crashes
Old 23-09-2008, 08:41 PM   #5 (permalink)
Super Moderator
asingh's Avatar
How are you over clocking the card..?? Are you just setting new setting, and then playing the game...??
I would suggest, to use ATI Tools (it is compatible with nVidia cards). Increase the core/memory setting 10 notches at a time, and scan for artifacts..for ten minutes..after each increment. Your shader clock should move respectively on its own, since it is linked. Once you get artifacts, come back down a notch at a time. Safe this profile..and GAME ON...!
asingh is online now
Old 23-09-2008, 08:48 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
DONT try to Overclock XFX 8600s unless you check the at what temperature they are running. If they run above 80C then don't even think about Overclocking.
http://twitter.com/akshayms
nvidia is offline
Old 23-09-2008, 10:10 PM   #7 (permalink)
mayanksharma's Avatar
well, try reinstalling the drivers along with the rivatuner. and may be, as you have DDR2 version of 8600, thats why, u arent able to overclock that higher.
mayanksharma is offline
Old 24-09-2008, 12:12 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
That's no point, check the link I've given, there u;ll see they are using DDR2 512mb versions!!!
About me:
Old 24-09-2008, 12:57 PM   #9 (permalink)
Whats no point?
The link u've given constitutes only one post for 8600GT!! And thats too yours!!
I just said him to try reinstalling the drivers OA.
and btw, DDR2 versions arent mean for overclocking. And even if somehow it does, then they wont attain higher clocks.
Old 24-09-2008, 01:16 PM   #10 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Well... The 8600GT that too DDR2 version is not exactly and overclock-friendly card AFAIK. Thats my 2 cents.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 24-09-2008, 02:07 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Hmm, and it overheats(I've heard of Electric Stove Edition) so be happy wid it's performance, and later upgrade when u really need it
About me:
Old 24-09-2008, 07:34 PM   #12 (permalink)
PSN~ftw
well guys thnx for reply but isnt maybe my psu the cause of the problem............ i only have a 450w psu bundled alongwith the zebronics lava pc case????????????? yes and my card is not even exceeding temps of 70 degree celcius
Old 25-09-2008, 12:54 AM   #13 (permalink)
well, may be or may be not. Coz, u said that Core overclocked quite well. right? so, thats enough for the psu thing.
And for temps, yes its a good thing that it isnt crossing 70.
I say, stay with the card as long as it serves you my frnd and then dump it for a good replacement.
Old 25-09-2008, 06:41 AM   #14 (permalink)
Violent serenity.
Psychosocial's Avatar
Ya, dont worry OC'ing it. 8600GTs suck at OC'ing.
Add to that their temps. Its good you arent getting high temps.
Psychosocial is offline
Old 25-09-2008, 08:27 AM   #15 (permalink)
PSN~ftw
then can you recommend a good board and gfx card for 10k on which i can at least all Latest games like crysis warhead ............... and find it in delhi....
Old 25-09-2008, 09:33 AM   #16 (permalink)
Violent serenity.
what you can do is save on the mobo right now and keep the 945 which you have. It can be upgraded later. Spend all the 10k on the card.
Get a Palit HD4850 512MB GDDR3 for 9.5k ......... awesome card. Will play Crysis Warhead @ Very High settings at a resolution of 1440x900 .
If you want a cheap board, look at the XFX 630i for 3.4k.
But, whatever you do, dont miss out on the HD4850. Its an awesome card and will serve you well
Old 25-09-2008, 11:24 AM   #17 (permalink)
PSN~ftw
hey i am getting a 9800gt from malaysia and buying a intel p35/x38 asus board...
Old 25-09-2008, 11:27 AM   #18 (permalink)
Excessive happiness
Instead get a Palit HD4850 from Malaysia... that wouldnt hardly make any diff in purchasing a HD instead of worthless 98GT....
ASUS -> Good choice....
PS Request
Old 25-09-2008, 11:30 AM   #19 (permalink)
Violent serenity.
awesome!!!
THe 9800GT is just 8-11% slower than the HD4850.
Buy a MSI P35 Neo-F. Nice board coupled with an amazing card = terrific gaming .
Old 25-09-2008, 11:32 AM   #20 (permalink)
Excessive happiness
Originally Posted by KPower Mania View Post
awesome!!!
MSI Fan boy...
PS Request
Old 25-09-2008, 11:34 AM   #21 (permalink)
Violent serenity.
Worthless ?? No fukking way!!!! Its as good as a HD4850 and if you OC it, it will match the HD4850.
ASUS -->> Teriffic performance BUT at a premium
MSI -->> VFM (Value for Money)
MSI Fan boy...
d00d I dont wanna get into an arguement with you as I know you are a good, friendly guy who posts sensible stuff but I aint a fanboi.
MSI provides bang for the buck while ASUS only provides a bang albeit a bigger one but they are less VFM.....
guess I will leave it for guys like comp@ddict, desiibond and imgame2 to make you understand why I always suggest MSI boards to people on a hunt for VFM.
Last edited by Psychosocial; 25-09-2008 at 11:39 AM. Reason: Automerged Doublepost
Old 25-09-2008, 12:02 PM   #22 (permalink)
Excessive happiness
But if i OC HD4850!!!!!!!!!!
I just kidding say that u r a fanboi...
Here, he say that he get a ASUS x48,p35 mobo from Malaysia... Is there any point we advice him not to buy a Mobo which is somewhat a better than this...
PS Request
Old 25-09-2008, 12:29 PM   #23 (permalink)
Violent serenity.
Arguement over.......go for the ASUS P5K (P35 based) or the ASUS P5Q (P45 based) .... whatever falls under your budget. Happy ?
Old 25-09-2008, 02:20 PM   #24 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I stil thing P45 based mobo wud be better......
And Don't spend on any new gfx card right now, wait for the new HD 4830, and see, cause it'll be priced lesser I guee than 9800GT, but surely similar performance is what is esxpected...
And ya, if 9800GT OC performs like 4850, then what will 4850 OC do?
About me:
Old 25-09-2008, 02:24 PM   #25 (permalink)
Violent serenity.
Simple........will perform better than 9800GT OC .
I think HD4830 will perform a notch lower than the 9800GT....... but that is just an approximation.
Old 25-09-2008, 02:33 PM   #26 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yes, HD 4830 is supposedly wid 480SPs, nearly half of 4850, I hope the performance doens't get halved!!!loloz
and BTW-Why only H.A.T.E.?
About me:
What to do with my 8600GT SLI?? Harvik780 Hardware Q&A 26 25-09-2008 02:21 PM
8600GT 256MB or 8600GT 512MB? Sreeejith Hardware Q&A 53 29-10-2007 07:54 PM
8600GT or 8600GTS or 8600GT Fatality bajaj151 QnA (read only) 31 12-08-2007 08:38 PM
Matters of OCing and Heating crs_cwiz Hardware Q&A 17 16-03-2007 02:21 PM
OCing Transcend DDR400 quad master QnA (read only) 4 12-04-2005 08:57 PM
