22-09-2008, 11:41 PM
Strange no signal problem , Help neede badly
I am facing some problem with my comp ,
some times i get to see no signal on my monitor , some times the problem gets fixed by removing the monitor cable and turning on the monitor and later turn on with cable attached .
few times the same problem got fixed when i tried removing hdd data cable ...so the monitor flashed and showed the " hdd.... " usual message and after connecting the cables back it was fine .
This problem still exists and some times at most urgent situations my pc dosent start up , instead i get to see the very irritating no signal , and to add the pain none of the tricks i mentioned above works then .
And forgot to tell another imp problem when going through the above procedure , this computer turns off soon after turning on and after few secs it turns on again
hope my explanation is clear enough
What could be causing this problem ? ? ?
My sys config is
Abit ip-35 e, C2d e 6750, Xfx 6800 Gt, 320 Gb sata II samsung hdd , 2*1 gb transcend 800 mhz ram .
Please help me fix this , i am very much in need of a sincere machine  .
23-09-2008, 12:13 AM
Searching for Anti-Matter
Re: Strange no signal problem , Help neede badly
Can't point out the exact cause.Try checking each device one - by -one.
Check ur ram first! Also try removing ur bios battery or flushing ur cmos.
Looks like ur cabinet is haunted by some dead PC's ghost ....
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
23-09-2008, 10:50 AM
in that case i must check out the 2 pieces of transcend ram  , i have got no cheating processor so far
as u said my p4 based sys must be haunting , only the p4 processor survives still  .
I am using a frontech 500 W power supply .. is this enough , frontech cab look ugly and quality is worst too  .
Would be happy if some one would suggest me a good cab and power supply under budget 3-5 k
23-09-2008, 11:19 AM
GaurishSharma.com
I suspect VGA cable is your monitor is faulty.
Try change it, new one comes for around 150 bucks
23-09-2008, 06:34 PM
I dont think soo , cos this is causing restarts too at boot , so any how not relating to the VGA cable .
23-09-2008, 08:57 PM
Dual boot is a known issue with Abit IP 35 boards and I believe it is fixed in the latest BIOS update.
23-09-2008, 09:45 PM
What exactly is a dual boot ? ? ? , i v been informed abt this from a long time , whats it ?
23-09-2008, 10:46 PM
dual boot as far as i know...and i guess he meant that to having the option to select to boot two or more OS from a single computer...
it is not related to your case..
how did you check the ram? memtest?
what about graphics card? did you check it on another PC?
what is your monitor..a CRT or LCD?
24-09-2008, 07:02 AM
I ve run the comp with single peice of ram alone , tried both , both are working fine once the pc is started Or else with both the pieces it dosent start up , as i said some changes in hardware brings back display. Wondering when this problem will pop up again
I havent done any other test on ram , if there is some particular good software please tell me .
Graphics card i havent tried on a diffrent system .
I am using a lcd monitor , its view sonic va 1912wb
BTw the issue with the board is double boot right , not dual boot !! , whats a double boot ?
24-09-2008, 11:56 AM
online sources indicated that it need to boot twice to be able to boot to windows
i have an Abit IP35 that always double boots when turned on from cold. By this I mean when I switch it on, it everything powers on but after a few seconds it all powers off again, then after a second it powers back on then boots fine.
http://forums.hexus.net/abit-care-he...boot-cold.html
just to be sure..clean the connectors of all components..and make sure that the graphics card is seated properly
25-09-2008, 08:40 PM
Now i got display , but it says hard disk boot error , so i removed the hdd data cable , started , then connected the power cable --started system , then connected them together and got the same message , so i changed the socket it was placed and now i am typing here
dont know how long i can remain like this
now the new problem is repeating
Reason: Automerged Doublepost
28-09-2008, 06:39 AM
need help guys ,  , forgot to say that my mobo never double booted so far after i bought , this is the first time all this happening  and getting the no display
29-09-2008, 07:26 AM
My mistake, I meant to say Double boot not dual boot.
29-09-2008, 11:25 PM
Double boots was fixed in bios update 12 , i am running 14 , and never had this trouble so far
13-10-2008, 03:58 PM
I cleared cmos and it began working fine , now i flashed to the latest bios version too no trouble at all
13-10-2008, 04:06 PM
Fullbring
@last..just like hindi movies..happy ending
15-10-2008, 06:32 PM
and i learned the value of a floppy drive which these days get no attention at all ..
16-10-2008, 09:12 PM
Point Blanc
well soon they too will go, as flash drives or USB drives can be used to flash the bios.
