Old 22-09-2008, 10:52 PM   #1 (permalink)
The Black Waltz
Default Are these temperatures normal?
These are the temperatures of my PC components. Plz tell me if the temperatures are fine or not.
GPU (XFX 6600GT 256 MB)- 60 C on average
HDD (Samsung 80GB)- 50 C
Proccy (AMD 64 Athlon 1.81 Ghz)- average 45 C
mobo core (ASUS A8NE)- average 45 C
When I game, the temperatures rise by about 5 C. The GPU temp rises by about 10 C.
#krow @ irc.freenode.net
Cool Joe is offline
Old 22-09-2008, 11:04 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Are these temperatures normal?
Proccy temps r normal, don't know abt others
Blogging at:
Technostarry
saqib_khan is offline
Old 22-09-2008, 11:44 PM   #3 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Mobo is ok.
CPU is ok.
HDD is near to ok.
GPU is slightly higher.
For Intel core temp & case temp info read my post here - post #2 .
It also gives an idea about cpu temps in general - may be useful for u.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 23-09-2008, 04:24 AM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
GFX is "the" XFX 8600GT Hence the temp is ok.
infra_red_dude is offline
Old 23-09-2008, 06:26 AM   #5 (permalink)
The Black Waltz
^^Mine is not the 8600 GT, it's the 6600GT
@power user- Your post was not helpful. Mine is an AMD 64 proccy.
Cool Joe is offline
Old 23-09-2008, 11:26 AM   #6 (permalink)
Wire muncher!
Lol.. Misread it! 6600GT idles around 55C if I remember rite. So not much to worry about I guess!
Even proc.. both the proc and gfx card a just a bit on the higher side. You may wanna clean the cabinet and the fans.
Old 23-09-2008, 11:57 AM   #7 (permalink)
No pain....No gain
john_the_ultimate's Avatar
All of the temps are fine, except for the HDD. A front intake fan and a lil bit of cleaning should help it.
I had the exact same config a couple of years back and temps seem fine.
Just look out that the proccy doesn't cross 60c at any given circumstances.
6600gt has a threshold of 130c so........ on average 60c is normal. If you can, then clean the heatsink and apply a fresh layer of AS5/MX2 thermal paste. Both for the gpu n cpu.
john_the_ultimate is offline
Old 24-09-2008, 11:42 AM   #8 (permalink)
The Black Waltz
Ok.... I'll clean my PC once exams are over.
Cool Joe is offline
normal temperatures..!! magneticme200 Software Q&A 2 06-05-2008 10:23 AM
Are these temperatures OK?? BULLZI Hardware Q&A 8 31-03-2008 12:16 PM
Cpu Temperatures The_Devil_Himself CPU / Motherboards 4 06-09-2007 12:26 AM
Tell the normal temperatures codename_romeo Hardware Q&A 3 15-11-2006 11:14 AM
CPU Temperatures teknoPhobia CPU / Motherboards 38 19-10-2005 12:48 AM
