Old 22-09-2008, 10:40 PM   #1 (permalink)
Default Help on a complete HTPC solution
Hi all,
Need some feedbacks and help in deciding on a new PC. Well, basically I am looking at an HTPC set-up. I am planning on well dedicating a full room for a real home theatre setup. A few options that I am looking at are jotted bellow.
Since visual and sound are the at-most priority for an HTPC, I want to keep the components in a mid-range level and just for one or two components in the top range. Though budget isn’t a constrain I would like to keep it in a check.
Presently being put up in Saudi for a short project I am thinking of assembling it over here.
Speakers:
Logitech Z – 5500 Digital.
A lot of reviews here were very much positive about this product. I zeroed in on this due to its DTS capabilities. Thinking of using it through optical SPDIF cables. Is anyone here using the Z-5500 with optical cables?? Is it really worth it?? Have there been any troubles in setting it up??
This is the only thing among the components that I kind of have confirmed upon.
Processor:
AMD or INTEL
Apart from it being an HTPC, it will be also be used for ftp transfers at which case it might be powered 24 x 7.
What I am presently looking at are AMD 4800+ or Intel Core 2 Duo E7200.I read that AMD consumes only 45w compared to 65w (If it is wrong, Sorry for misinformation) which will help in the power consumption too. But which one is better for an HTPC, do mind that other that these two uses and a bit of surfing this PC doesn’t have much of a use.
Motherboard:
My present options are if AMD then Gigabyte GA-MA78GM-S2H or Gigabyte GA-MA69GM-S2H, Asus M2N32-SLi Deluxe, Foxconn A79A-S. For Intel I thought of Asus P5B Deluxe, Gigabyte GA-EG45M-DS2H OR GA-X48-DQ6.
These motherboards became the choice since they seemed to be an all-round deal. The real help I need is here. These motherboards (except the Gigabyte boards for Intel) have HD support GPUs and all have DTS connect and optical SPDIF out. A doubt I have is that, Will a motherboard with all these features really be able to give the same performance as an individual graphic and sound card?
If the verdict is that never will a mobo be able to be the perfect solution then please recommend some good boards.
Memory:
2 x 1 GB 800 MHz (if the above motherboards can do all the work)
Else
2 x 1 GB 667 MHz
Storage:
160 GB SATA – II or 250 GB SATA – II
Optical Drive:
Any DVD – RW or LG Blu-Ray Combo. Suggestions??
Powers Supply:
CoolMaster 550 W. Any other Suggestions??
Interface:
Logitech or Microsoft Wireless Combo. Suggestions??
TV Tuners:
??? No idea. Read about LeadTek Winfast TV 2000 XP and Pinnacle TV tuner kit for vista here. Others I found were Leadtek DTV 2000H, Hauppauge 2200 or Compro E700.
KNC ONE TV – Station DVB S2 has a CAM interface module so that I believe in our Indian condition will work with the DTH providers, but is there some other method for such with a normal TV Tuner card.
Projector:
I have no clue as to which one I should be looking at.
CPU COOLER:
Suggestion??
[As I said before if the conclusion is that these motherboards will not be sufficient then only there is a need to think about these two categories
Graphic Card:
XFX 8600 GT, XFX 9500 GT or ATI HD3450
Sound Card:
Creative X-Fi Titanium Fatal1ty Pro, Asus Xonar D2, or Auzentech HDA X-Plosion 7.1 DTS Connect. Any user feedback on these cards??]
Please do help out with your suggestions and comments.
Thanks in Advance.
jobinjv is offline
Old 24-09-2008, 04:37 PM   #2 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Re: Help on a complete HTPC solution
You get everything d00d... Just go assemble it ...
E7200+Gigabyte X48-DQ6+2GB DDR2 800MHz+WD 640GB(HTPC always need this much space)+ASUS DVD RW+Corsair VX450W+Logitech Combo+Pinnacle(Model No... I juz forgot it)+Panasonic Projectors are best in line+ThermalRight Ultra 120Extreme+HD4670(Released b4 diwali).. or.. HD3450/8600GT+ Creative X-Fi Fatal1ty Pro....
The above is my pick....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 24-09-2008, 04:51 PM   #3 (permalink)
Caballero de Real Madrid
m-jeri's Avatar
hehehhe.. ur buliding my system.... ??? in which mobo+proc+ram are a year old affair though... still more than enuff
but my display will be a LCD...must... a 26" sony or panasonic... or if i can afford a 32..that ...
remove ur projector.. the high qlty ones with HD and all will go beyond a lac... so opt a large LCD 24" + ...
but mine not a pure HTPC... i will soon buy a shuttle dx10.. love the touch screen...and hook it to my HT setup... and then wi fi it to my rooms HTPC..thats the idea.. atleast in next 6 months...
and get a intel proc+mobo any good u afford ...
2 GB RAM...
500 GB HDD ... 250 or 160 ??? WTF?? its s aHTPC r8?? where will u store the A/V ... have other storage?? portable..external or NAS???....
LG or SOny SATA 22x
Try Corsair TX 650 ..more than enuff.. but urs too is good..
get MS wireless... or the ultimate KBB the logitech Dinovo..costs 12k...then a wireless mouse..MS or Logi...
Get a tuner with SAT connector..otherwise not for future...
so ur not into gaming...atleast get a 4850...if u want to game..thats why...let it be ther...
the titanium ones are with PCIe ..thats all...no other diff...
|PC-15R-i3 M530|3GB DDR3|320GB|5470 512MB|500 GB Ext|D/L-D410PT|1GB|500GB|E122|APEX MI - 100|A/V-E2200HD|PS3 80GB+AT90USB162|Z5500 D|10TB|MOMO Wheel|APC 1KV|Click-500D|18-55 IS|
m-jeri is offline
Old 24-09-2008, 05:08 PM   #4 (permalink)
Excessive happiness
Hmmm.... ok.. just get a HD4850 at least...
PS Request
Old 29-09-2008, 02:02 AM   #5 (permalink)
well, the mobos mentioned were chosen so that i can have an optical spdif. As far as storage is concerned I currently have a WD passport 160 GB, WD My Book 500 GB, Custom case 100 GB.
No gaming since i will hook it up with an Xbox later.
a theatrical sound is my priority with good display.
jobinjv is offline
Old 29-09-2008, 10:11 AM   #6 (permalink)
m-jeri's Avatar
then igonre my suggestion abt the hdd and ..dont ignore the card.. buying a good card is needed coz if ur pc wanna handle HD res.. for spks ur set..then buy a lcd.. far better and easy on ur pocket..
m-jeri is offline
Old 29-09-2008, 11:34 AM   #7 (permalink)
You gave been GXified
gxsaurav's Avatar
Add a XBOX 360 if u r into games
about.me/gxsaurav
gxsaurav is offline
My HTPC - the long brief Ponmayilal Reviews 39 21-04-2008 07:13 PM
Dell 3yr Complete protection Vs 1yr Complete Protection... Suggestion needed sakthirajesh Buying Advice 5 07-12-2007 03:01 AM
HTPC configuration sarulan PC Components / Configurations 3 18-11-2007 11:49 AM
HTPC Query Charan Hardware Q&A 16 06-10-2007 06:19 PM
HTPC suggestion hitman050 Hardware Q&A 1 19-05-2007 12:45 PM
