Hi Guys,
I have a Second PC thats really old. Its got a very simple config.
Pentium3 600MHz ,20Gb HDD+ 8 GB HDD, 128 MB SDRam, CD writer. With Windows XP SP2.
I have two problems with this :
Problem 1. Ive been facing a problem with it since a while. Earlier the HDD drives+ CD Writer would not detect on 1st boot, then a reset and they would detect and the PC would function normally.
This persists since some time.
Today nothing comes on the screen at all at boot . I opened up the case to see that the processor fan was spinning, I could eject my CD writer Tray. I cant make out if the HDD Drives are spinning as I have to unscrew them and see it.
I disconnected all the secondary storage and checked with no HDD/CD. Still no display.
The PC is roughly 8.5 years old. Its not my primary PC, but a PC that is used for selective things.
Is it that my power supply is failing or is the Ram ? Or what else please suggest .
Problem 2. Assuming all of the above is fine, when I connect the PC onto a network and start say Internet Explorer to browse, the minute my page loads my PC hangs.
I checked this with other applications too, the minute some sort of data transfer takes place the PC hangs.Eg: Antivirus Update, Google Talk, Utorrent.
However, a PING request to google.com and I dont face any problems.I get Ping responses perfectly.
Please help me solve these two problems. Thank you .
