22-09-2008, 12:22 PM
Maximum Fame
Cabinet/chasis for Thermalright Ultra 120 extreme
Hello guys I wanna buy a cabby which can accommodate my thermalright Ultra 120 extreme
My budget is around Rs 3000 any help is welcome  .
ASUS P5N32E-SLI,XFX 8800GTS 640MB SLI,Intel Core 2 Duo E6600 Oced @3.01Ghz,Thermalright Ultra 120eXtreme,Corsair HX-620W PSU,250 GB Sata Seagate & Sony Sata AWG170S DVD writer,Asus Supreme FX Audio.
22-09-2008, 02:24 PM
Re: Cabinet/chasis for Thermalright Ultra 120 extreme
Cooler Master Elite series, i have CM Elite 332 Cabinet, last month brought a OCZ Vendatta 2 (120mm Fan with Cooler) cooler for my CPU, so just removed the chimney from the side panel of the Cabby to fit the Cooler.
U can also look in for Cooler Master CM690 Cabby, link : http://www.theitwares.com/cabinets/cabinets.htm
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
22-09-2008, 07:43 PM
Searching for Anti-Matter
I m using CR690-CM690 with thermal right ultra 120 ext.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
22-09-2008, 10:05 PM
Violent serenity.
CM690 without transperant side panel is costing around 2.8-3k.......awesome cabinet.
22-09-2008, 10:48 PM
The Black Waltz
+1 for CM690.
Best cabby you can buy for the price.
#krow @ irc.freenode.net
22-09-2008, 11:46 PM
I m having rc690-cm690 with transparent side window. Got it @ 4.5k. Its an Awesome cabby!!!
23-09-2008, 12:09 PM
Maximum Fame
The CM690 is good but it does not fit in my budget hows the Centurion 534.
23-09-2008, 07:50 PM
Violent serenity.
you have a budget of 3k and CM690 without transperant panel costs 2.8k.
If thats also out of your budget then CM Elite 332 will be a good choice at around 2.2k.
24-09-2008, 08:32 AM
In Kolkata CM690 without transperant side panel costs around 4K.....
24-09-2008, 10:12 AM
Maximum Fame
Thanks guys for ur replies.I've decided to go for the CM690 cabby.
24-09-2008, 10:04 PM
you can't get CM690 in 3K guys
join my orkut community to download latest movies, music & games here's the link to view it http://www.orkut.com/Community.aspx?cmm=38665088
24-09-2008, 10:15 PM
Violent serenity.
^^You can.....without the transperant side-panel.
