Old 19-09-2008, 10:04 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Angry Monitor Moisture
From last week whenever i boot up the monitor screen is black & it takes 5-10mins
2 come to the normal view....bcoz of moisture....???
how do i get rid of dat....shud i keep a silica gel near monitor or some other solution is there ??
Zangetsu is offline
Old 19-09-2008, 10:26 AM   #2 (permalink)
Ethan_Hunt's Avatar
Default Re: Monitor Moisture
Same problem here too.Though in my case takes around 10 secs to regain the screen status.Any solutions?
V for Vendetta
Ethan_Hunt is offline
Old 19-09-2008, 05:50 PM   #3 (permalink)
ur talking about CRT monitor right?
i think you might have to call the TV repair guy to have a look (probably need a replacement of certain part)..or you can open it yourself and clean it..
realdan is offline
Old 19-09-2008, 05:56 PM   #4 (permalink)
Ethan_Hunt's Avatar
Mine is still under warranty, so might as well call the Viewsonic guy to have a check.
V for Vendetta
Old 19-09-2008, 06:01 PM   #5 (permalink)
yes..if in warranty..do not open it..just claim them
realdan is offline
Old 21-09-2008, 06:57 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
yes
its due to moisture if i m not wrong....(same goes to allwinindia...
Zangetsu is offline
Old 22-09-2008, 12:30 AM   #7 (permalink)
Scott274's Avatar
Even I have this problem. When I open the monitor sometimes the screen looks very dark and takes 3-4 minutes to come back to normal. Is this some bad hardware problem. Aren't there any solutions to it.
Scott274 is offline
Old 22-09-2008, 10:20 AM   #8 (permalink)
Fullbring
Zangetsu's Avatar
It usually happens during rainy seasons..moisture gets down to the components when not in use & when using heat kills them...
well i'll try myself & will update this thread soon
Zangetsu is offline
Old 22-09-2008, 11:05 AM   #9 (permalink)
paroh's Avatar
yes same problem with samsung syncmaster 763DFX (CRT) . some times it takes 5-6 minutes to become normal . but now the image quality is not clear Text is not visible as it should be little blue. More pain to eyes.
so i advice u to move to LCD monitor.
paroh is offline
Old 22-09-2008, 01:20 PM   #10 (permalink)
Scott274's Avatar
Isn't there any no-cost way of avoiding this moisture.
Scott274 is offline
Old 22-09-2008, 09:25 PM   #11 (permalink)
maybe buy those silica gel in a packets ..i think it is also called desiccant that you mostly find in bottle of medicine tablet..and also in some food package...to absorb moisture..
maybe stick those inside..the monitor..several of them...that might in a way help to control moisture...
but hey one can also take out the back cover and clean the CRT tube..it can quite dirty..all those black dirts..etc
realdan is offline
Old 23-09-2008, 10:00 AM   #12 (permalink)
Fullbring
Zangetsu's Avatar
+1
Zangetsu is offline
There is a ghost in my monitor!!!Monitor going crazy!!!!!!need help..... tango_cash Hardware Q&A 1 13-12-2007 12:03 PM
need to buy an lcd monitor CHETHAN N TVs / Monitors 7 23-01-2007 04:01 PM
Can moisture destroy my p.c???? tango_cash Hardware Q&A 12 27-07-2006 03:58 PM
i think i have a solution for moisture problem!!!! tango_cash Hardware Q&A 5 05-07-2006 07:33 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
