Old 19-09-2008, 12:15 AM   #1 (permalink)
Question #Urgent!!! External HDD(USB Connected) but Which 'n ...
" Urgent !!! "
- Want to buy an External HDD connected through USB Cable, , , but need u'r suggestions :-
Which Brand - Seagate or Wester Digital (WD) ?
Who's giving - The more Time For Warrenty - ?
What's the way - Seagate or Western Digital - Replace the Old HDD(if having Problem) and Give New External HDD ?
# Heard that The Western Digital Warrenty - works like Calling To Their Customer Care Phone Number and They Come and Pick-Up The Old External-HDD (if defective) From The User's Locaton .... Do The WD Also Sends The New-Replaced External-HDD to that User's Location ? ....
# In the Seagate Warrenty - The User have to go to their Service Centre... Is That Like That ?
Also - Plz tell me If I Buy The External USB HDD ONLY BUT WITHOUT It's HDD-Case( HDD Enclosure ) and Buy an External USB HDD Case( HDD Enclosure ) of Tech-Com - will that Separate-Combination work Fine ?
Plz. Reply .
rayshatadru is offline
Old 30-09-2008, 04:39 PM   #2 (permalink)
static_x's Avatar
Default Re: #Urgent!!! External HDD(USB Connected) but Which 'n ...
u can go for either seagate of WD..both have 5 yrs warranty and they'll replace the drive in case of any manufacturing defects or failures...i've got 2 HDDs replaced from both the manufacturers...both have got the facility of home pick up...need not worry about that...
static_x is offline
Old 04-10-2008, 01:07 AM   #3 (permalink)
thank you , for u'r reply,
Old 04-10-2008, 01:25 AM   #4 (permalink)
Call me Sumit
esumitkumar's Avatar
WD FTW @!!!!! Go for it !!
esumitkumar is offline
Old 06-10-2008, 10:41 AM   #5 (permalink)
M$™ Certified Spammer
entrana's Avatar
seagate isnt bad at alll either. u can just go for the cheaper one. BUT STAY AWAY FROM SEAGATE INTERNALS!!BAD BAD !!!
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 06-10-2008, 10:44 AM   #6 (permalink)
Steady
Get the Western Digital Mybook ..
Ph4x0r is offline
Can 256 MB be connected with 512 MB photon QnA (read only) 2 16-10-2007 09:15 PM
Urgent: External hard disk corrupted amitgg QnA (read only) 2 07-09-2007 04:51 PM
Is there anyway a tv can be connected to a computer? bavda QnA (read only) 2 27-11-2006 03:55 PM
ISP always connected fanatic QnA (read only) 6 21-09-2004 10:04 PM
