Old 18-09-2008, 05:50 PM   #1 (permalink)
Exclamation memory crad problem!!!!!!!!!!!
hiiiiiii guys!!!
i have nokia 6233 & i have 2 memory cards!!!!
1GB & 2 GB
there's everything fine until yhis happens..........
when i was changing my 1st mem card (1GB) & was switching to 2GB card!!!!!!!!!!
The card on mobile says,,,"Memory card not formated,,, format card???"""
Now what should i do???
i must recover my lost files!!!!!
please help!!!!!!!!
sushantade is offline
Old 18-09-2008, 06:00 PM   #2 (permalink)
Ethan_Hunt's Avatar
Default Re: memory crad problem!!!!!!!!!!!
Wait a minute.You need to be a bit more clear with your problem.
Which memory card says "Memory card not formated...format card???"
Try inserting the memory card into a memory card reader if possible & see if it gets detected.If it does then you can back up all your data.
V for Vendetta
Ethan_Hunt is offline
Old 18-09-2008, 06:21 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Reported for posting this in like four forums till now.
dheeraj_kumar is offline
Old 18-09-2008, 08:59 PM   #4 (permalink)
Juke Box Hero
Please post in one section only. All except one in Mobile Monsters Section are deleted!
Hitboxx is offline
Memory problem with my L6i! nutz_phoenix911 Buying Advice 1 15-03-2007 05:49 PM
memory problem Saumyakant QnA (read only) 1 08-05-2006 04:20 PM
Big Memory Problem??? Plz Help... go4saket QnA (read only) 1 08-11-2005 01:41 AM
best graphic crad around 5k shivi4 QnA (read only) 1 23-07-2005 07:18 PM
Memory problem sohin QnA (read only) 1 08-03-2005 06:12 PM
