18-09-2008, 08:41 AM
Budget PC at 15000rs.
Hi, Im assembling a budget PC to install and train on SAP software.
I guess it needs a lot of RAM and a good processor.
+I will be using office for project work.
Please suggest me a computer within 15K.
I will use my laptops screen as monitor(can that be done?)
Good processor
RAM
Motherboard (on board graphics)
HDD
DVD RW
CABINET
Keyboard and Mouse
Speakers are not needed...
deiibond any inputs from you would be a great help.
18-09-2008, 11:22 AM
Excessive happiness
Re: Budget PC at 15000rs.
Good processor
RAM
HDD
DVD RW
CABINET
Keyboard and Mouse
AMD Rig
AMD X2 4800+ - 3450 or 5200+ - 3675
ASUS M2N MX SE - 2350 or M2N MX SE Plus - some what higher than m2n mx se
2GB DDR2 667MHz - 1800
250GB WD SATA - 1800
Samsung/LG/Sony - 1.1k
Zebronics Bijli - 1.4k
Logitech Combo - 0.9k
ASUS/Mercury 8600GT 256MB DDR3 - around 3k...
Total - around 16.2k
Intel Counterpart
E7200 - 5.5k or E4500 - 4.8k
XFX 630i - 3k
2GB DDR2 - 1800
250GB SATA WD - 1800
Samsung/LG/Sony Drive - 1.1k
Total - 15,500
U r kidding....
Anyway choice is urs....... Hope u get the point... U need to run SAP so u need a medium power rig....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
18-09-2008, 11:55 AM
Originally Posted by rajkumar_pb
AMD Rig
Intel Counterpart
XFX 630i - 3k
2GB DDR2 - 1800
Total - 15,500
U r kidding....
thanks for your quick reply rajkumar_pb.
So you mean to tell, using laptops screen with the CPU is not a good idea.
What do you suggest? Intel or AMD?
18-09-2008, 12:00 PM
Democracy is a myth
Using Laptop screen as the main display with ur CPU is a weired idea, I'm not getting how u r planning to do it?
Can you please elaborate?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
18-09-2008, 12:03 PM
Excessive happiness
U r welcome
Yes.... get a new monitor... a 17" CRT would cost about 5800 and 15" CRT for 4000
I always suggest a Intel personally... But here in ur case AMD is the bang for buck and if u would spare another 3k for intel rig get a ASUS EN8600GT and it slash away the AMD counterpart.. if u choose E7200 as proccy.....
PS Request
18-09-2008, 12:12 PM
ASUS EN8600GT is the graphics card right. I guess i dont require a graphics card right now.
As i said ill go for intel.
Does the config you gave have onboard graphics.
18-09-2008, 12:16 PM
Excessive happiness
Yes.. XFX 630i has a better onboard graphics and if u would able to buy a GFX card after some time sure you make it as a medium-powered machine...
So u decide E7200+XFX 630i+2GB DDR2 huh rite....
Anyway go get the Intel Rig man.... Good choice.....
PS Request
18-09-2008, 12:21 PM
Will get the Intel Rig man... Thanks for your quick responses.
I think ill have to buy a Monitor too.
I have a CRT monitor 17 inch. It has a peculiar problem. I have to keep switching on the monitor power button nemerous times, to get it to work. Sometimes in 5 tries, sometimes it seems like forver clicks.
18-09-2008, 12:32 PM
Excessive happiness
Go to the nearest service center to fix the problem in monitor and it doesn't cost u more than 750bucks for servicing...
If not so, then get a 17" CRT for around 5.8k(more or less).....I prefer a LG and ViewSonic .....
PS Request
18-09-2008, 12:36 PM
Ok will do raj
18-09-2008, 12:47 PM
Excessive happiness
Ok will do raj
PS Request
18-09-2008, 02:40 PM
Bond, Desi Bond!
1) First and foremost, check how much disc space does SAP version that you have eats. The latest one is said to take up more than 200Gig.
2) yes. you can use your laptop to connect to your desktop (use vnc or netmeeting). That is not a big concern here
3) To run SAP you have to concentrate most on
Processor
HDD
RAM
HDD: Seagate 500GB 32MB buffer SATA2 HDD. Rs.3k to 3.5k
Processor: Intel Core2Duo E7200 for 5k-5.5k
Mobo: GA-EG31MF-S2 :3k-3.3k or Gigabyte GA-G33M-S2L: 4k or XFX 630i. I pick XFX 630i
RAM: 2Gig Kingston DDR2 800: 2k-2.1k
DVD writer: Sony/Samsung: 1.1k
Keyboard: TVSE Gold: 1k or Logitech multimedia: 400rupees
Mouse: Microsoft optical: 400rupees
Mercury/Kobian cabinet: 1.2k-1.5k
18-09-2008, 02:51 PM
Democracy is a myth
He does not want to connect both the machines, he wants to use the Laptop screen as his Desktop monitor ( Thats wat I understood from his description)
Ur procedure will surely work but, in that case he has to configure his CPU first, like OS install, drivers etc, how would he do if he doesn't have a standalone monitor?
B/W just found this......... link
Reason: Update
18-09-2008, 03:13 PM
Thanks desiibind for your suggestions. rhitwock is correct. That is how i wanted to use the laptops screen as monitor for the CPU.
Thanks for finding the details man.
But now i have decided to mend my old 17 in CRT monitor to work with the CPU.
getting the laptop screen to act as a monitor for another system sounds trouble, i wont go there.
Ill get the software system requirements and let you know.
20-09-2008, 01:20 AM
Point Blanc
I agree with desi, vnc or better say a software is what will get you use the laptop monitor, there is no port to connect to laptop monitor, so be clear in this front first.
HDD cappacity more than 250 GB to leave sapce for SAP, it needs minimum of 160 or 180 GB and you also need to install OS and many other apps.
But even it get it(vnc or any remote desktop) working you need to have a monitor first to initate this
I will personally say get DG31 supports max 4GB or DG33 supports max 8GB RAM.
630i chipset does not supports dual channel RAM, so RAM efficiency will be little lower.
ANd also there is a catch here, intel original motherboards cost alot much higher than MSI or Gigabyte, hence get MSI or Gigabyte
2GB 800 FSB RAM costs 1800
for monitors my personal suggestion is get a 17 inch LCD than getting a CRT.
You can get decent config in 20K including monitor.
