| Forum |
#1 (permalink) |
E6850 Core 2 Duo 3 GHz XFX 680i LT SLI Board Sparkle GeForce 8800GT 512 MB graphics 2 Gigs Transcend 800mhz DDR3 320 GB WD SATA HDD 500w Zebronics Platinum power It was working fine, then stayed idle for about a month when I was out of station. Now when I came back and turned it on, the HDD light stays on solid and does not blink. Also, the monitor led turns blue for a second when I power the machine on, then goes back to orange (standby), indicating no output from the card. What could be wrong? |
#2 (permalink) |
-----ATi-----
Check if your monitor cable is connected to the card properly..
And remove your card and replace it.. Does your computer boot? Do you hear the startup sounds of your OS?
http://twitter.com/akshayms |
#4 (permalink) |
well if it was idle for a month..then dust/moisture has caught up with the various components of your system. You can let it be switched on for several mins..and then see if it solved the problem on subsequent reboot or you can take it apart clean the connector and put everything back it place after the cleaning..
Q6600 | p5n32e-sli | 2x1gb Kingston ddr2800 |2x250gb seagate hdd | sony dru-190A | creative sb audigy2 zs | xfx 8800gt | corsair hx-620 | antec 900 | Ms basic desktop 500 | logitech z2300 | apc 800va |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 5.1 output........Please HELP ! ! ! | zany | QnA (read only) | 48 | 20-03-2009 06:51 PM |
| Output Screen In C++ ! | BBThumbHealer | Programming | 7 | 08-03-2009 06:10 PM |
| Using the s-video output | rajaram_s | Hardware Q&A | 2 | 02-06-2008 11:53 PM |
| need following output in c++ | bhushan05d251 | Programming | 7 | 22-03-2008 06:48 PM |
| How can i get computer output on tv instead of my monitor. I dont have tv tuner card | arunks | QnA (read only) | 5 | 12-09-2007 01:07 PM |
