| Forum |
#1 (permalink) |
"DISK BOOT FAILURE. INSERT SYSTEM DISK AND PRESS ENTER" I can enter into BIOS setup . I made the boot sequence devices as First Boot Device: CDROM Second Boot Device: Hard Disk Third Boot Device: Removable disc. I have got a new hard disc installed in the computer and wanted to install the OS. Now I put the XP installation disc and turn on the computer ... I am getting the error. Can anyone help me? |
#2 (permalink) |
Even I am having this problem. Everybody told me my hard drive was slowly going bad and to get a new one. You say you had a new hard disk installed. Don't know but it might be a manufacturing hardware problem in which case return it back to the shop or you might have done something wrong while installing the drive.
#4 (permalink) |
spice it up
this boot failure error doesn't always means dat HDD is bad/crashed ....its a rather a rare case ..
it can happen when system while booting cant find proper windows installation due to files corruption or when no OS is not found... use a "Bootable" XP Installation Disk to install & set First Boot Device as CDROM ... so you'll get a message something like "press any key to boot from CD.. " |
#5 (permalink) |
Searching for Anti-Matter
Usually this happens when ur MBR is wiped out - a simple reinstall/cleaninstall may do the job.
Also check if thr cd is bootable or not and the CD-rom is detected in bios.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ... |
#6 (permalink) | |
yes...the dvdrom is detected in BIOs. The installation disk is also bootable as i installed XP severel times from it. Quote:
>>>> took the CPU to the service center today. The DVD Writer was the culprit. Though it was detected in BIOS but it could not read the disk. Last edited by buzzzzrr; 18-09-2008 at 08:50 PM. Reason: Automerged Doublepost |
#7 (permalink) |
spice it up
DVD writer problem!!! .... dat was really least expected in ur case...more so since it was detected in BIOS
well we can never understand wat can happen when....true regarding machines too |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Disk boot failure | shivg33k | Software Q&A | 2 | 26-05-2008 08:33 PM |
| "Hard disk Failed Press H to retry or enter to boot from other device " | uzair | Hardware Q&A | 7 | 01-04-2007 12:33 AM |
| Boot Disk Failure | vineetrocks2005 | Software Q&A | 2 | 07-05-2006 07:52 PM |
| Boot Disk Failure | StalinQAA | Software Q&A | 3 | 31-12-2005 02:28 AM |
| invalid system disk please replace the disk and press any ke | montsa007 | QnA (read only) | 13 | 06-06-2005 11:16 AM |
