Old 04-10-2008, 11:36 PM   #31 (permalink)
Noobness unleashed....
Default Re: Urgent suggest a lappy
i will have to go for the supplied battery coz i have already overshooted the 60k budget.
but tell me 1 thing do we have to change laptop batteries after a certain period of tme just like mobile and inverter batteries??
in that case can i upgrade from a 6cell to 9-cell that time or is it not possible??
No mortal can keep a secret. If his lips are silent, he chatters with his fingertips; betrayal oozes out of him at every pore.
- Sigmund Freud
prakash.gourav is offline
Old 04-10-2008, 11:57 PM   #32 (permalink)
Point Blanc
yeah sure you can do that. Besides people generally who need extra battery, they keep in reserve with the default battery. Also the battery life is good long same as in mobile, hence chances of you buying a new battery is less in 1 year span or more.
Besides people generally run on adptor than more on battery, having continous power supply, but if its not the same in your house then 9-cell will be recomended. Where do
you live prakash.
acewin is offline
Old 05-10-2008, 01:00 AM   #33 (permalink)
Yeah i too plan to use it by adaptor. I live in saharanpur where power cuts prevail too much but most of the time i shall remain in my coleg where there is 24 hrs power supply.
Nd wen da tym comes to replace the battery , i wil replace it with a 9 cell depending upon my needs. Thanx
- Sigmund Freud
Suggest A Lappy < 50K BBThumbHealer Hardware Q&A 30 07-09-2008 02:37 AM
Plz suggest a Lappy in 50k range fun2sh Buying Advice 32 07-09-2007 01:32 AM
Suggest a Lappy please!!! (Kinda urgent guys!!!) preethesh.shetty Hardware Q&A 1 10-05-2007 09:31 AM
lappy budget=Rs. 1 Lac...suggest the best Ishan QnA (read only) 1 17-09-2006 06:29 PM
Which lappy ? (50-58k) [urgent] mohit Mobiles and Tablets 7 09-07-2006 03:37 PM
