Old 16-09-2008, 02:48 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default Creative sound blaster 5.1 + Altec Lansing VS3251
Hi guys..
Finally I have purchased Creative SB 5.1 and connected it with my Altec..I switch on the speakers, press 5.1 button in the remote..everythin works fine except for the Center/SW. There is no sound at all from it.
Searched net, one solution is to pull out the Center/SW pin from the speaker and it should work. !@#$%
I did the same, but nothing changed..but I noticed when unplugging and replugging there was sound from Center/SW..so out of curiosity I slowly plugged in the cable and half way thru I get the SW and Center sound.
Now I have left the SW/Center cable plugged in halfway in the Speaker.
Why is this happening???
Any Solutions???
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 16-09-2008, 08:09 PM   #2 (permalink)
moshel's Avatar
Default Re: Creative sound blaster 5.1 + Altec Lansing VS3251
so is everything working fine now? cos even if the cable is just half plugged in, as long as its working properly there shudnt be any problem.
moshel is offline
Old 16-09-2008, 09:11 PM   #3 (permalink)
Gracias Senor
dreams's Avatar
^^I agree..but curious 2 knw why is it happ..also sometimes the jack looses and power to SW/Center stops. So need FIX.
dreams is offline
altec lansing 121i or creative sbs 370 r2d2 Hardware Q&A 7 16-12-2007 06:38 PM
Creative or Altec Lansing kameyameya Hardware Q&A 13 18-06-2007 11:17 PM
Please suggest: Creative SBS 370 OR Altec Lansing AVS 300 krish Hardware Q&A 3 07-02-2006 01:53 PM
Altec Lansing ATP3 or Creative Inspire 4.1 ???? invisible Hardware Q&A 21 05-02-2006 11:34 PM
