| Forum |
#1 (permalink) |
I got new SE k790i phone... i connected it to my pc via USB cable n installed the drivers as per instuctions... but when i transfer a song it takes long time. for example transferring a song to its memory card of 10 mb it takes approx 2 mins, which is very painful... what shud i do to transfer it faster... My pc config is as below P4 1.6ghz 632 Mb Ram 845 Motherboard Windows XP SP3 Thanks
Saurav Best Possible PC Configuration or Dream PC - http://www.thinkdigit.com/forum/showthread.php?t=51297 |
#2 (permalink) |
Legen-wait for it-dary!
Use a memory card reader, and put the mem stick on it. arnd 100 bucks in the market. very fast data transfer rates.
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
#5 (permalink) |
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Once you connect your fone, the phone memory and the card memory show up as removeable drives under My Computer, just do as you would with a usb drive. Keep in mind to maintain the folder structure.
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain |
#6 (permalink) | ||
yes u r right... it shows as removable drives under my computer and i used it the same way u said.. but its very slow yaar.. i loaded a 10mb song under
Memory Stick->Music->Songs and it took around 2 mins of time... Quote:
Saurav Best Possible PC Configuration or Dream PC - http://www.thinkdigit.com/forum/showthread.php?t=51297 Last edited by sr_garg; 17-09-2008 at 06:37 PM. Reason: Automerged Doublepost |
#8 (permalink) |
I got 632MB ram in my pc... isn't that enough..
#9 (permalink) |
hey anyone help plzz..... someone plz solve the prob...
#10 (permalink) |
Wise Old Crow
USB 1.1 or USB 2.0?
Try connecting cable to different USB ports. Do you face similar problem when connecting pen-drive?
http://twitter.com/blueshift155 |
#11 (permalink) |
yes it has got USB 2.0 i tried using different usb ports available in my pc but no use.. i use sandisk cruzer 2gb pendrive but it is very fast...
#13 (permalink) |
the transfer speed bet the phone and PC via Cable is USB 1.1!!!!
no matter what system you have it will take time.all SE phones transfer at that speed. BT is faster and a Card reader is perfect(you get the complete speed of USB 2.0) |
#14 (permalink) | |
TechFreakiez.com
r u sure abt wht ur saying ..using a USB 2.0 cable how can ne1 get speed of USB 1.1???
Personal Log | Star date 05.04.2009: TDF Meet Kanpur was Awesome www.TechFreakiez.com |
#15 (permalink) |
ok sry....im not sure if it is USB 1.1 but its definitely slower than USB 2.0.ive been using SE's for quite a long time and when i transfer huge content i use a card reader!
#16 (permalink) |
M$™ Certified Spammer
which mode do u use phone mode or usb mode. try usb mode its faster. but the speeds are really slow its not a "problem"
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| >>Review : Sony Ericsson K790i<< | devilhead_satish | Reviews | 14 | 03-03-2009 09:40 PM |
| Sony Ericsson K810i or K790i??? | pranavrahul | Mobiles and Tablets | 13 | 03-07-2008 12:35 PM |
| Sony Ericsson K790i or Nokie N73? | srikat | Mobiles and Tablets | 11 | 28-06-2007 10:46 PM |
| Price of Sony Ericsson K790i? | sabret00the | Mobiles and Tablets | 31 | 10-02-2007 11:56 AM |
| Does Any One Have Sony Ericsson's K790i..PLs Help | Pravas | Mobiles and Tablets | 1 | 06-12-2006 04:09 PM |
