View Poll Results: preffered way 4 external SATA hdd
external casing 3 50.00%
pci card 0 0%
SATA to USB cable 3 50.00%
Voters: 6. You may not vote on this poll
Old 11-09-2008, 04:15 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default preferred way 4 External SATA hdd
which of them u prefer ??? sata 2 usb is my choice ....... whot abt u ?
... W H O T ...
ax3 is offline
Old 12-09-2008, 09:48 PM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: preferred way 4 External SATA hdd
If you mean connection, the best is either eSATA(fastest) or Fireware(very fast but<eSATA)
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is online now
Old 15-09-2008, 11:03 AM   #3 (permalink)
The Frozen Nova
casanova's Avatar
I plan to use eSATA but am not able to find some good power option. Any pointers.
I have used external casing previously but that bulky power adapters take the fun away.
www.nerdweed.blogspot.com
casanova is offline
Old 15-09-2008, 11:17 AM   #4 (permalink)
ax3
ax3's Avatar
me 2 afraid 2 connect my sata hdd 2 these socalled external cases .... as power adapter acts as the killing agent ......
any other option ?
like just connecting using usb port & power taken from cpu ....
... W H O T ...
ax3 is offline
Old 17-09-2008, 02:49 PM   #5 (permalink)
tkin's Avatar
any other option ?
Let me correct that, SMPS/PSU(not CPU) provides power to internal HDDs only, so no luck there, either get an internal HDD or don't.
BTW what do you mean by "power adapter acts as the killing agent ......?"
Be honest- No other options. Get a Seagate Free-Agent Pro, and use a eSATA if you have one or a Fireware, USB is the last option, its just too slow.
tkin is online now
Old 18-09-2008, 11:36 AM   #6 (permalink)
ax3
ax3's Avatar
@tkin ..... killing agent = killing agent ..... ie main culprit 4 making dead hdd`s ....
... W H O T ...
ax3 is offline
Old 18-09-2008, 11:47 AM   #7 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: preferred way 4 External SATA hdd
It means, if ur using the external HDD( data read-write operation going on) and suddenly power goes off.......u know what happens.........
I've one 500GB Maxtor, had to format the entire HDD for the same reason, Luckily dumped my contents to one of my frnds' HDD, so I'm saved. (But lost 22GB imp. data).
Now I've bought a spike buster, connected it to UPS and Put my HDD adapter to it. Anyone using an external HDD requiring external power should follow this. Or u r living on the edge.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 20-09-2008, 12:48 AM   #8 (permalink)
Point Blanc
external casing or SATA to USB are same, I have tried both.
SATA to USB cable is same as external casing, just their is no casing. they also use external power adaptors
Whatever form you use, as ax3 said, the problem is with power adaptor, their build is cheap. If you have good adaptor it would be good.
so final verdict is either you use internal or dont. Considering external buy branded as they come with good power adaptors to make them run longer.
acewin is offline
Old 20-09-2008, 12:59 PM   #9 (permalink)
ax3
ax3's Avatar
@rhitwick & @acewin which ext. cases r u using ???
i wanna do it AGAIN .....
... W H O T ...
ax3 is offline
Old 21-09-2008, 05:35 AM   #10 (permalink)
Point Blanc
I have used supercom casing for HDD(already screwed), genius casing for my burner(working good even after one year). Though the adaptor is cheap and I took it from my friend as my roommate gave the adaptor of the box to someone else. That one was also same.
Today I bought again a casing, this time coolermaster in 1100, good to see it has good adaptor and good build overall. The casing for IDE HDD, I had got my 80GB seagate replaced, and wanted to use it but as I do not have a desktop I bought this case.
acewin is offline
Old 22-09-2008, 01:23 PM   #11 (permalink)
ax3
ax3's Avatar
@acewin .... will try 2 get them ..... thanx .....
... W H O T ...
ax3 is offline
Old 22-09-2008, 02:31 PM   #12 (permalink)
Democracy is a myth
rhitwick's Avatar
Wink Re: preferred way 4 External SATA hdd
Not using any case,
Bought External HDD of Maxtor.
The one u r talkin are actually laptop hdd which is turned to USB hdd by that casing.
Discussion on External HDD converted from Internal HDD using SATA-USB Casing Udaya Maurya Hardware Q&A 23 25-08-2008 07:20 AM
Want to buy an internal SATA HDD and convert it into external HDD Udaya Maurya QnA (read only) 11 26-03-2008 07:53 PM
External Casing for SATA HDD debaisaindian QnA (read only) 6 18-01-2008 11:27 PM
Sata in external case with old comp ranjan2001 Hardware Q&A 20 06-06-2006 08:30 PM
