Old 10-09-2008, 08:21 AM   #1 (permalink)
Tribladez rizes to power
jeffrain123's Avatar
Default Suggest SMPS around 1k
Pls. Suggest a powerful SMPS around 1k to power the following-
E6300@3 Ggz
XFX 630i
4 GB DDR2 RAM
EVGA 9800GTX
2 HDDs 160GB & 250GB
SONY 16x DVD RW
E6300@3.2Ghz ||IP35-E ||4GB OCZ NVIDIA SLI EDITION @ 900Mhz ||EVGA GTS 250 512MB ||500GB CUDA 7200.12 ||OCZ STEALTHXSTREAM 600W ||17" SAMSUNG 740N ||JVC RX-816V ||PIONEER S-LF3-CR+INSPIRE 2500=5.1CH
jeffrain123 is offline
Old 12-09-2008, 11:26 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: Suggest SMPS around 1k
just curious: have you already bought the motherboard and the graphics card ?
If not, and if you plan to buy a GPU seperately, I think G31 based Gigabyte board would be a better choice for overclocking.
And 9800GTX is not worth it, compared to HD4850 and 9800GT.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 13-09-2008, 01:55 AM   #3 (permalink)
Point Blanc
Antec 400W PSU, best in sub 1K, would cost around 800-900
acewin is offline
Suggest me a reliable Mobo+Proccy+Smps Hackattack Hardware Q&A 1 25-01-2008 08:50 PM
Help meee!!20 pin SMPS to 24 pin SMPS? sourav Hardware Q&A 9 25-09-2006 10:37 PM
Smps ??? spyne Hardware Q&A 2 08-05-2006 02:27 AM
SMPS for high end systems?? plz suggest hotdogXP Hardware Q&A 3 26-01-2006 08:04 AM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
