Old 09-09-2008, 10:20 PM   #1 (permalink)
Default Suggest Laptop Confg.
I am going to purchase a new Laptop in the next coming days. Please suggest me a good & suitable configuration for my Laptop, I am purchasing this Laptop for general purpose use not for gaming etc.
cool_kumar28 is offline
Old 09-09-2008, 10:29 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Suggest Laptop Confg.
Do you want a light weight 13" or performance laptop?
what's your budget?
desiibond is offline
Old 10-09-2008, 12:34 AM   #3 (permalink)
Krazy_About_Technology's Avatar
Budget Please. Waise in general, I recommend buying a Dell Laptop, the inspiron 1525 with 2 GB RAM and 160 GB HDD is a good config to start with @ near about 37K. Next choice for me is HP and then Compaq. A big no-no is acer specially with their low end CR@P!!!!
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 11-09-2008, 03:45 AM   #4 (permalink)
Point Blanc
Right now I would recommend Compaq and HP Pavilion notebooks available in market which are with good specs. They would be Dell's config in same price.
Otherwise if you need customization then go for dell for sure you will have wide range of choices as per your thinking.
So, first check your budget. My suggestion is get a notebook with decent or good onboard gfx provided because running vista would need much better gfx card than general onboard intel x3100, this would again help you to keep your lappy in work nxt 3-4 years easily.
acewin is offline
Old 11-09-2008, 11:58 PM   #5 (permalink)
^^ Buddy, Having a good graphics card is another thing, but Vista run as smooth as it can on X3100. I have it, i use it and i know it.
Suggest a laptop for 45k ankushkool Laptops and Netbooks 5 16-08-2008 12:03 PM
Suggest me a LAPTOP plz panacea_amc Laptops and Netbooks 14 25-07-2008 12:53 PM
Suggest a Laptop to buy? 6ranjitha6 QnA (read only) 11 20-10-2007 11:43 PM
Suggest me on which laptop to Buy... saipradeepg Laptops and Netbooks 3 19-02-2007 07:17 PM
Amd Confg rohus24 Hardware Q&A 6 31-10-2006 11:16 PM
