Old 09-09-2008, 09:14 PM   #1 (permalink)
reniarahim1's Avatar
Unhappy Mercury 845Gl Ndsmx display driver issues
I am facing the following issues in my mercury 845GL NDSMX mother board,
1. Its not showing the resolution of 1400x900 in windows xp even though it is showing resolutions above that.i installed my monitor driver cd also but it also solve the problem.
2.I am unable to get the display drivers for the same for vista.from where can i download the drivers?
reniarahim1 is offline
Old 09-09-2008, 10:45 PM   #2 (permalink)
aswin1's Avatar
Default Re: Mercury 845Gl Ndsmx display driver issues
Older motherboards dont support resolution of 1400x900. Not likely to support vista either.
Install a graphic card if you have an AGP slot or go for a new motherboard.
aswin1 is offline
Old 10-09-2008, 01:16 AM   #3 (permalink)
The board has a DVO slot (w/o AGP support) it says as per the user manual. is there any graphics card available in market now for this board with 1400x900 resolution support as well as vista support?
Or is there graphics card which can be used in PCI slot?
Old 11-09-2008, 12:43 AM   #4 (permalink)
aswin1's Avatar
DVO slot is of no use. Very difficult to get a PCI graphics card. Even if you get one it wont support 1400x900 resolution.
aswin1 is offline
Old 17-09-2008, 06:13 PM   #5 (permalink)
I am getting the Resolutuion of 1400x900 in Ubuntu but not in Windows..Why????
In case windows dont support this resolution on my 845GL motherboard, please suggest the cheapest PCI graphics card that support this resolution as well as vista. I don't use the system for any Games or 3D purposes and all. Normal Movies, browsing and thats all..
Old 17-09-2008, 06:20 PM   #6 (permalink)
Excessive happiness
furious_gamer's Avatar
Hard to say that, just change ur Mobo with a good IGP like nVIDIA 7150/630i chipset.. I have a ASUS Mobo with 7050 NVIDIA IGP which supports that resolutions at ease... So go for a change man.... It'd roughly costs u abt 2.5k(+/- 300) or a bit more..
XFX 630i - 3.2k
Palit N73V - 2.7k
ASUS P5N-MX - 2.5k
Zebronics NF7050 - 2.2k
Choice is urs........
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
mercury 845gl chipset monny Hardware Q&A 9 16-03-2009 10:45 AM
Display Issues Plasma_Snake Gamerz 8 15-07-2008 09:33 AM
Will Mercury 845GL motherboard support 512MB DDR RAM AT 333/400 MHZ jiteshbhimani Hardware Q&A 8 07-07-2007 08:59 PM
Driver Issues ToxicSerpentz Software Q&A 1 05-04-2007 09:40 AM
Driver Issues undertakerthedead QnA (read only) 4 04-11-2004 11:02 AM
