Old 09-09-2008, 01:45 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Question Shocking USB Port!!!
Hi...my frnds usb port is giving electric shock(not high)...wats the problem...
Zangetsu is offline
Old 09-09-2008, 02:15 PM   #2 (permalink)
Treatment in progress...
mukherjee's Avatar
Default Re: Shocking USB Port!!!
is ur pc properly grounded(earthed)???
that might cause the prob!
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 09-09-2008, 04:03 PM   #3 (permalink)
Then every metallic part of your computer will be giving a shock.
Reason-No or faulty earthing.
ThinkFree is offline
Old 09-09-2008, 04:04 PM   #4 (permalink)
prasad_den's Avatar
Yeah.. most likely there is no proper earthing in the power supply. Rectify it quickly, else it might damage the HDD and other internal components...!
prasad_den is offline
Old 09-09-2008, 04:17 PM   #5 (permalink)
whats ur mobo dude ?? i had a simtronnics mobo which used to do that cos of that i lost one kingston 4Gb USB
chilling.....
imgame2 is offline
Old 10-09-2008, 10:00 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
MSI.....& its not mine my frnd has...i think earthing is not a problem bcoz if it is then
the monitor screen will also give a shock which is not so in this case...
Zangetsu is offline
SHOCKING - Is it Taj Mahal or Tej O Mahalya ? techtronic Fight Club 57 05-09-2009 12:16 PM
Shocking Discovery Plasma_Snake Gamerz 2 26-05-2008 12:28 AM
This is shocking!! You have to see this aritrap Mobiles and Tablets 15 01-02-2008 06:29 PM
Shocking! IPod + Lightning Equals Trouble marulez Technology News 14 14-07-2007 01:33 AM
'Shocking' Problem In Cabinet Vyasram Hardware Q&A 14 29-12-2005 06:44 AM
