Old 08-09-2008, 10:00 PM   #1 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Default Does my Cooler master 600 W SMPS need grounding ?
Hi guys - Just want to ask a question about my PSU/SMPS.
I have Cooler master extreme 600W - PCAR PSU.
The thing that irritates me now and then is that the power cable that came with it did NOT have an earthing or grounding PIN in it.
It was just having 2 pins - the +ive and the -ive pins.
SO do i change my power cable having 3 pin socket or continue using the original cable having 2 pins ????
IS there any harm with 2 pin cable ?
PLZ reply as soon as possible!
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 08-09-2008, 10:14 PM   #2 (permalink)
Treatment in progress...
mukherjee's Avatar
Default Re: Does my Cooler master 600 W SMPS need grounding ?
i dunno how it came to....but its ESSENTIAL to use a grounded connector for as vital as a component as an smps.
get it ASAP....and dont compute in the meanwhile...u cud b putting ur components...hell...evn ur life at risk...
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 09-09-2008, 01:43 PM   #3 (permalink)
channabasanna's Avatar
My CM 600W PSU has the same problem, the power cable supplied had no earthing Cable, so i used my old unused Power Cable, which is working fine.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 09-09-2008, 07:15 PM   #4 (permalink)
k thx
Old 09-09-2008, 07:26 PM   #5 (permalink)
mukherjee's Avatar
get proper grounding ASAP bro!
u have a system to save!!!
Old 07-12-2008, 02:04 PM   #6 (permalink)
damn even i bought a Cooler Master 500W Extreme Power Plus yesterday and it didn't have earth(grounding) pin. that irritated me a lot as well coz the thing costed a lot and now they dont even provide a proper cable with it. seems i have to stick back to old psu's cable. but will the local psu cable fit cooler master psu's backside point?
ravishing is offline
Where can i get Cooler Master SMPS in Chennai pcgamer Hardware Q&A 1 24-05-2007 12:47 PM
