Whenever I switch on my computer, CPU starts up and after 2 secs, the power goes down (CPU fan stops) and again after 2 seconds, the CPU powers up. I am not sure why this is happening. Can someone provide a fix for this?
If it is constant restarting of the PC,it'd be due to the faulty pressing of the power key.(I used to have it if i press it with more pressure on one side).Pls explain in detail......
I think its the double boot issue present in IP35e's..
You should check out abit forums for the double boot issue, there are some sticky threads regarding double boots.
No, I do not hold the Start button for a long period. After the CPU starts the second time, it boots to the OS properly without any hitch. It just happens for the first time whenever I start my PC, after which there is no problem.
