Old 07-09-2008, 03:16 PM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Suggest a gud mouse
I have a standard logitech mouse, but i want somethin better. I want it for graphic designing n casual gaming. How is iball precise for rs.550?
My budget is rs.1000 max
Is logitech mx518 worth rs.1350
ankushkool is offline
Old 07-09-2008, 07:54 PM   #2 (permalink)
Violent serenity.
Psychosocial's Avatar
Default Re: Suggest a gud mouse
iBall sux to core Believe me, I have used their mouse.
Anyways. MX518 is worth every penny You wont regret the purchase.
Otherwise, look at Microsoft Optical 2000 .
Psychosocial is offline
Old 07-09-2008, 08:03 PM   #3 (permalink)
Lets Do It!
amrawtanshx's Avatar
Get the Logitech mx518
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 08-09-2008, 12:22 PM   #4 (permalink)
ankushkool's Avatar
so i think i will have to go with MX519... is there any cheaper option???
Old 08-09-2008, 12:38 PM   #5 (permalink)
Cool G5's Avatar
I also found Microsoft mouse comfortable. Donno the model no.
Cool G5 is offline
Old 08-09-2008, 12:53 PM   #6 (permalink)
Violent serenity.
MX518 justifies what you pay for........go for it.
Otherwise the other M$ mouse I mentioned is a cheap alternative
Old 09-09-2008, 02:37 AM   #7 (permalink)
Point Blanc
iBall sux big time, even normal logitech is better than them
acewin is offline
Suggest Mouse ruturaj3 Hardware Q&A 8 18-06-2008 07:47 PM
i need a new mouse.pls suggest me. tango_cash Hardware Q&A 15 15-05-2008 09:46 PM
~= Please Suggest a Good Mouse Under 1K =~ Vishal Gupta Hardware Q&A 15 11-07-2006 01:41 PM
Mouse Problem . help & suggest <> hellomotto Hardware Q&A 4 12-03-2006 08:38 PM
Pls Suggest the BEST UPS, Keyboard, Mouse... Vishal Gupta QnA (read only) 11 30-08-2005 07:08 PM
