Old 06-09-2008, 07:20 PM   #1 (permalink)
ashfame's Avatar
Default Need 2.1 set
I am looking for good 2.1 set which are either equivalent or higher in performance than Creative SBS370.
My budget is 1.5k but I can buy something like ATP3 in ~1.8k too.
A friend told me about Altec Lansing BXR1121, Creative t3030 n t3100.
Kindly suggest something.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 07-09-2008, 09:44 AM   #2 (permalink)
Default Re: Need 2.1 set
if u can get atp3 for 1.8k , its the best deal. .otherwise , get creative inspire m2600 .
sagargv is offline
Old 09-09-2008, 09:28 AM   #3 (permalink)
ashfame's Avatar
More suggestions plz?
ashfame is offline
Old 09-09-2008, 01:14 PM   #4 (permalink)
Lets Do It!
amrawtanshx's Avatar
Go for Creative Inspire 2.1/Altec Lansing VS2421.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
