Re: iPod Touch - restore mode
Restore mode is when the iPod is ready to get updated. Either you initiated the Restore mode somehow (usually pressing the Home and Sleep buttons together for 10secs or so), or the iPod software is corrupted and needs to be restored. If its the first case, just press and hold those two buttons together, and it will come out of the restore mode. If its the second case, you need to restore you iPod by downloading the update.
If you are close to an Apple store, just take it there and they will restore it for you.
I'm like a bird... :)
