Old 05-09-2008, 05:09 PM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Unhappy What is this problem with my PC
My pc sometimes when switched on stops at the first screen showing the Motherboard manufacturer label.. Sometimes it goes further to boot in and then freezes at the
desktop screen .. What is this problem..?? This doesnt happen always but unfortunately for almost 85%of the time. Can anyone identify the problem and the solution?
BIOS label reports harddisk has some problem and needs to be replaced. But CHKDSK shows no problem. So I am not sure about it. By the way wish to know any free tool that can diagnose disk problems.??
"Just Keep swimming"
windchimes is offline
Old 05-09-2008, 05:17 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: What is this problem with my PC
I guess in a few days u'l b visited by BSOD.........
Check ur RAM power connections.......
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 05-09-2008, 05:29 PM   #3 (permalink)
Can you hear it..??
windchimes's Avatar
POWER seems to be ok...
Can you please explain it in detail and any solution..I dont want to see that Blue screen on my pc
Old 05-09-2008, 05:43 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Oh..........I forgot to put a "comma" b/w RAM and Power.........
Check ur RAM in ur frnd's PC..........
If using more than 1 modules..........check both of them in both slots one at a time..........
Old 07-09-2008, 08:26 PM   #5 (permalink)
Can you hear it..??
windchimes's Avatar
I Formatted my windows installation drive and after reinstallation it works
fine. No warning when booting in..
BUT..Again it freezes at times. I've seen this happening mostly when connected to net.
(os -win xp , RAM-2GB, Browser - Opera latest version)..
Anyone knows the solution..??
Old 08-09-2008, 04:01 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Could also be a probme with SMPS.
I had a problem where windows used to crash whenever I connect extra fan to my desktop (side fan). That was after I added a new GPU. SMPS couldn't provide stable voltage to all the compnents and if I remove the extra fan, I used to get windows back.
Also check the IDE/SATA cables. A problem with the cable can't be ruled out.
desiibond is offline
Old 08-09-2008, 01:53 PM   #7 (permalink)
ECE0105's Avatar
Had the same problem with a Friends PC... Just removed the Processor and Heatsink and put it back in and reset the BIOS via Jumper... That fixed it...
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Old 08-09-2008, 03:24 PM   #8 (permalink)
Violent serenity.
Psychosocial's Avatar
run Memtest..........seems a prob. with RAM
Psychosocial is offline
Old 08-09-2008, 07:16 PM   #9 (permalink)
uchiha_madara's Avatar
@windchimes:
Same thing happened to me ,found out that I had one faulty RAM stick.
One smart Avatar .
"Any sufficiently advanced technology is indistinguishable from magic"
Clark's Law
uchiha_madara is offline
Old 08-09-2008, 07:24 PM   #10 (permalink)
Section Moderator
gopi_vbboy's Avatar
may be ur ram freq is not supported by ur motherboard
gopi_vbboy is online now
Old 08-09-2008, 08:08 PM   #11 (permalink)
sagar_jxd's Avatar
this is the problem from ur motherboard it is not working properly u shuld contact the dealer n tke suggestion frm and if u hve the warranty period of motherboard till now u should immediate handover ur motherboard to the company n complain wht u r having........
sagar_jxd is offline
Old 08-09-2008, 08:48 PM   #12 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Dear windchimes.
Well, AFAIK I had the same problem 4-5 years ago with my Pentium II machine. The problem was with the processor. It was overheating. Check whether the fan and heatsink are properly attached or not.
Regards;
IronMan.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 09-09-2008, 02:05 AM   #13 (permalink)
Can you hear it..??
windchimes's Avatar
Thanks for the myriad of suggestions..
So is it mobo, processor, ram, smps, fan, heatsink..??
Mobo has no warranty. System detects the entire 2GB RAM.
And I was thinking it had something to do with faulty cluSters in HDD thoguh my machine is
not detecting it. No one commented on the same
CAN ANYONE RECOMMEND A GOOD FREE SOFTWARE FOR TESTING SYSTEM HARDWARE..??
Old 09-09-2008, 03:37 AM   #14 (permalink)
Point Blanc
anything can be the issue as guys suggested. But highest chances is of SMPS (it has gone weak and is not suitable), change it and test other hardware.
2nd would have been RAM becoming incompatible or any of the two going bad, seems less as u said both are getting identified and working fine.
Because next comes loose connection in putting proccy heatsink and all connectors.
So once you are sure of your SMPS deassemble all your components and fix them again properly.
acewin is offline
Old 10-09-2008, 02:18 PM   #15 (permalink)
Hi Windchimes,
If u have any device installed to USB like USB modem, then remove it and boot the PC. I used to hav the same prob, but later figured it out.
Sunsky is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
