Old 04-09-2008, 11:47 PM   #1 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
Exclamation Plz suggest a good ups for my 600W requirement
Hey guys , can some of u suggest me a good ups for 600w requirement.
I'm having a 600W C.M. SMPS/PSU and will go crossfire in future so my requirements may jump to 650W or 700W.
Plz suggest a good ups with high efficiency to handle power between 650w to 700W max.
Power_user_EX is offline
Old 05-09-2008, 10:23 AM   #2 (permalink)
toofan's Avatar
Default Re: Plz suggest a good ups for my 600W requirement
Go for APC brand reliable and secure.
toofan is offline
Old 05-09-2008, 10:33 AM   #3 (permalink)
Deadly Creature Me!
ubersoldat's Avatar
Hi,
U can definately go for APC. Go for a UPS with a rating of 800VA to 1KVA. U can also bet ur money on SuKam. Very stable UPS. Also, disconnect the monitor from the UPS line. Give it the direct wall connection.
Bye.
Hi again,
No need of connecting the monitor to wall connection if its a LCD. The thing is, u cannot be sure with CRT monitors. They r power hungry monsters and could very well reset the best ups's around. So be cautious.
Bye.
ubersoldat is offline
Old 05-09-2008, 08:48 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Get APC..
So it shall be written..so it shall be done..................................!
asingh is online now
Old 05-09-2008, 08:59 PM   #5 (permalink)
Lets Do It!
amrawtanshx's Avatar
Get APC ..
I bought it today ... And its way better than Intex.
Sorry for comparing APC & Intex though.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 05-09-2008, 09:18 PM   #6 (permalink)
Originally Posted by amrawtanshx View Post
Get APC ..
u should be sorry ....cos APC is way better ...!
chilling.....
imgame2 is offline
Old 05-09-2008, 09:22 PM   #7 (permalink)
Violent serenity.
Psychosocial's Avatar
Intex is crap.
YOu can try iBall too.
My friend has the iBall Nirantar UPS and he gave me a positive report about it.
Psychosocial is offline
Old 05-09-2008, 11:29 PM   #8 (permalink)
shashank4u's Avatar
Today i bought a APC 650 VA, 350 watts UPS, Price RS 3200... also the dealer said APC gives onsite service. If you want a cheaper alternative than go for microtek.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 05-09-2008, 11:42 PM   #9 (permalink)
thx guys!!!
I surely go for APC then. But will 850VA rated ups @ 400 to 600W (or may be more) handle my rig's load ?
My question : if my rigs sucks 550W continuous power and ups is of say.. 700VA @ 450W then what will happen to pc ? will it work or just reject the low input power ?
I may have a misconception .... will be gr8 if it gets rectified!!!
Old 05-09-2008, 11:47 PM   #10 (permalink)
shashank4u's Avatar
It will work.. but if the load is too heavy for the UPS then there will be a restart.
btw APC 800VA has 550 watts of power.
Old 06-09-2008, 01:08 AM   #11 (permalink)
Lets Do It!
Thats why I apologised
Old 06-09-2008, 05:05 AM   #12 (permalink)
Point Blanc
well we had bought 800VA UPS of HP for my friend worked very good and gave almost 20 minutes life for our system. also we kept it on for keeping the Broadband ADSL model on. But when I asked the shopkeeper when another of my friend was buying system for the HP UPS which worked very well for us, he said its not available they had received alot compaints and the service of HP to rectify any related isses was bad.
Bought 1KVA microtek UPS, working fine I hope, havent asked much about it from my frn, besides electricity goes off very less at his place.
what about UPS from Powersafe
acewin is offline
Smps 600w ... where to put UPS plug ? pirates1323 Chit-Chat 2 27-04-2008 03:16 PM
suggest a good tv tuner card with good recording capability NiluGeek Hardware Q&A 1 06-10-2007 08:28 PM
Suggest good SE for 6k Gigacore Buying Advice 6 13-07-2007 05:28 PM
