Old 04-09-2008, 10:14 PM   #1 (permalink)
Default what should i do now?
today i bought creative Inspiron 4.1 for my laptop ..
but when i tried to connect there was only one slot on my laptop for speakers..
so when i put the wire into that slot i was able to get sound from only two speakers and not from the other two..
is there any way out?
NauticA is offline
Old 04-09-2008, 10:16 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: what should i do now?
You may need a separate sound card... or check for 2.1 to 4.1 sound jack.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 04-09-2008, 10:35 PM   #3 (permalink)
where should i check out?
what be the cost of usb sound card?
NauticA is offline
