Originally Posted by nvidia
+1
Get an ATi HD4850 for 9.5k and OC your processor to 3-3.2GHz.
Then you'll see the difference. Just OCing your current rig won't give you any kind of advantage.
i will surely think of ur suggestion nvidia
Originally Posted by comp@ddict
absolutely, the e7200 is known to touch 4GHz with stock cooling.
But I recommend that you OC to around 3.4 GHz, no point after that, why make ur processors life hell.
And get a
1. 9600GT from Zotac for 6k
OR
2. 9800GT for 7.5k
OR
3. 4850 for 9.2k
Check for best prices in: www.lynx-india.com
u r right yaar ... but how to OC ie .. are there any seperate software for it ..i m using asus p5k mobo
Originally Posted by desiibond
Do NOT mess with voltage. Increase FSB speed. Do stress testing. You can find lot of overclocking guides on the internet.
Stop at the best speed that does all the work you want.
how to increase FSB is it done thru bios ????
plzz guide my freind
Following are some of my Mobo specs
1. To attain top performance, ASUS engineers have successfully unleashed the true potential of DDR2 memory. While CPU is running under FSB1066/1333, ASUSīs exclusive technology offers a choice of
DDR2 1066(O.C*) - providing great performance for 3D graphics and other memory demanding applications.
2. On my Mobo box its written as u can OC to 1600 FSB
now how can i achice it & after acheiving it if i wish to come back at my original settings can i come back ???
