Old 04-09-2008, 02:44 PM   #1 (permalink)
Default Lappy help
I want to buy a laptop. Budget is 60K. Decided to go for Dell studio 17 with Radeon 3650 or XPS 1530 with 8600GT. Both with 4GB RAM. My question is......Is 3650 equivalent to 8600GT? I heard some of XPS 1530 came with faulty 8600GT previously. Is it true....?? Or it's safe to buy XPS1530 now?? Second question is.....Is buying 7,200 rpm hard drive a good option??
parimal is offline
Old 04-09-2008, 03:18 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Lappy help
go for HD3650. 8600M has heat issues
desiibond is offline
Old 05-09-2008, 03:03 PM   #3 (permalink)
Hi,
As i have heard from the reviews both these graphics cards are not upto the mark and get heated up a lot.
If your budget is around 60k go for hp dv5-1015tx which comes with a Nvidea 9600GT with 512Mb dedicated and a very good processor too.
The graphics card has very nice reviews and the graphics memory in HP can be max 1.5GB shared so could play nearly all the games in decent resolutions.
The lappy is 15.4" and has a TV tuner card too but it would cost you a bit more than your budget aroud 65k but its worth it.
A
AshwinDR is offline
New lappy...?? alekh_khanna QnA (read only) 3 12-01-2008 10:00 AM
lappy under 35k SunnyChahal Mobiles and Tablets 6 03-12-2007 12:30 AM
Lappy for 42k??? gauravakaasid Mobiles and Tablets 10 05-12-2006 09:49 AM
Lappy Lappy Time...!! grinning_devil Hardware Q&A 3 15-05-2006 02:37 AM
